Old 18-03-2007, 08:27 PM   #1
El_Poochino
Default URGENT Who makes the HDD for HP
Hi guys.
Just need to know who makes the HDD for HP notebooks. Need to get a diagnostic tool.
Or if you know how to fix a PXE-E61 error message
El_Poochino is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 08:37 PM   #2
pertuan
Focus on my Focus
Hard to say. They usually have more than one supplier.
On bootup, during the BIOS POST test, you should be able to see a model number. Grab that model number and google it.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 08:51 PM   #3
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
Try googling PXE-E61 there are alot of results such as this one
http://www.experts-exchange.com/Hard..._21290425.html
They may help.
Old 18-03-2007, 08:52 PM   #4
Bluefreak
Bluefreak's Avatar
I've just poked around on www.computerforum.com and it seems the those who managed to 'fix' this had to do it with a new HDD...
Bluefreak is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 09:02 PM   #5
El_Poochino
Thanks for your help guys. Just finished chatting with HP support. They recommended sending it back to the store for a replacement. I agree, can't be stuffed fixing the HDD then having to run an illegal version of XP despite having a Vista licence, until I get my mitts on Vista.
Thanks again, mods can delete this.
Old 18-03-2007, 10:12 PM   #6
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
HP use Seagate ..
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2007, 05:45 AM   #7
Rodp
Regular Schmuck
Rodp's Avatar
Originally Posted by El_Poochino
Hi guys.
A PXE error is likely your notebook unable to find a boot device and is attempting to query a PXE server on your network through your network card in order to boot from it (which you obviously don't have).
Diagnostic tools are pretty useless. It could be a case of your boot sector being trashed on your hard drive or your hard drive has gone to silicon heaven. Try booting off an OS CD (like XP) to see if it can see a valid drive. Otherwise, off to the shop it goes.
Old 19-03-2007, 12:12 PM   #8
jonk
This is the matching error code explanation. It's a hardware error. Turn off LAN Boot/PXE Boot in BIOS. More stuff below.
PXE-E61: Media test failed, check cable. Most likely the cable is not plugged in or connected. Could be a bad cable, NIC or connection. Double-check that the HDD has the highest boot priority in the BIOS. If it does, but you still get the PXE errors, that most likely means that the HDD is toast. What's happening is that, failing to boot from the harddrive, the BIOS is "falling through" the other available boot options (hence the PXE messages).
jonk is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2007, 06:41 PM   #9
davocol
davocol's Avatar
and Toshiba, IBM and maxtor amongst others.
Originally Posted by AU2PWR
HP use Seagate ..
SZ Territory Titanium
davocol is offline   Reply With Quote Multi-Quote with this Post
