Old 05-12-2006, 06:45 PM   #1
FRDXR6
FRDXR6's Avatar
Default Registering NSW engineered cars in VIC
Has anydone done this before?
What im wanting to know is will Vicroads accept the NSW engineer report or will i have to go through the whole process again in Vic?
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2006, 09:12 PM   #2
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
I sold mu 1UZ-FE powered hilux dual cab 2WD to a fellow from Victoria. It was NSW engineered.
He was able to get it regoed in Victoria because it had a standard ECU and therefore was as much complied as an LS400.
Just a few.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2006, 12:24 PM   #3
FRDXR6
FRDXR6's Avatar
Do you know if he had to get it looked at by an engineer, or just gave the engineer papers to the Vic mechanic/Vicroads for RWC and he passed it?
The car is an early Toyota sedan running 1JZ-GTE, although it has an aftermarket computer it wouldnt be hard to return it to stock. The conversion is straight forward and everything basically bolts in and connects without fuss, so i couldnt see it having too hard a time getting registered.
Old 06-12-2006, 12:29 PM   #4
dansedgli
dansedgli's Avatar
Just find a RWC guy that will honour the NSW stuff. Some wont but some will ;)
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2006, 06:37 PM   #5
FRDXR6
FRDXR6's Avatar
Dan know anyone in particular that honour NSW engineers certificates?
The cars already in Vic and registered so would that mean because Vicroads has the new engine number on their system, they would be cool with the conversion?
Old 06-12-2006, 06:41 PM   #6
dansedgli
dansedgli's Avatar
Technically a NSW engineering cert is not valid in Vic, neither is a QLD blue plate.
I have a QLD blue plate for racing seats and I was told it wasnt vaild, Im like but those seats are not racing seats you goon and he denied my RWC anyway for the AIT compliance plate. He said it was dodgy. :(
I dont know anyone in particular but a few are in the mindset that the ADR's are the same nationwide so the engineers cert can be from anywhere.
Old 06-12-2006, 09:03 PM   #7
frost
frost's Avatar
My friend got her car registered in Victoria with NSW complaince
frost is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2006, 09:21 PM   #8
ROOSTA
DFDFDF
ROOSTA's Avatar
From my understanding.. in order to get a nsw engineers cert you have to present a vehicle with nsw reg.. if vehicle already has vic reg you have to get a vic engineers cert..
If vicroads already has new engine number on their system then it should be ok with them.. That doesn't mean the police will accept it though.. always better to have a valid cert for the state you in..
My 2 cents,
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 09:59 AM   #9
FRDXR6
FRDXR6's Avatar
My 2 cents,
Cheers,
Nik
The car already has a NSW engineers certificate, then it was bought to Vic and registered.
Its just so much hassle getting it engineered in Vic so im trying to avoid that if possible...
Old 07-12-2006, 03:53 PM   #10
xrgt
Big Motor Top Loader!!
xrgt's Avatar
I know the NSW RTA has a list of engeering signatories that it will accept certificates from. This list includes engineers from interstate.
I'd say all you have to do is ask VIC roads which engineering signatories it accepts. Compare the list. If no match, just try a few VIC engineers and see if they can issue you a new certificate base on the NSW cert.
good luck.
xrgt is offline   Reply With Quote Multi-Quote with this Post
