My new car's a '93 Telstar TX5 Ghia... I've just realised that the high beams don't work. The HB dash light doesn't even come on when I switch it on
Any idea what I can do to get it functioning? Last edited by timace; 20-12-2006 at 12:11 PM. |
Over Thinker
after the fuse then there may be a dip switch problem
if you know the high beam part of the bulbs are ok you need a volt meter to check where the power has stopped flowing start at the fuse then read what voltage is at the bulbs
My car goes Brumm Brumm |
Thanks mate, I'll check it out at lunch
