Old 02-01-2007, 12:47 AM   #1
Conrad
Default Focus Tunnel
Why do ford focus' have those driveshaft tunnels if they are front wheel drives and theres no drive shaft?
Conrad is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 12:49 AM   #2
LUXO_8
windsor user
often they're designed for other markets, where its possible to have an all wheel drive variant...
or they sometimes run the exhaust along it allowing better undercar clearance...
or, they designed them that way to allow for these
http://www.ford-v8-focus.com/index.html
Old 02-01-2007, 01:19 AM   #3
BlackLS
Posts: n/a
Also remember that the car is using in rallying so they'd want to consider the competetivness of the car as a rally car when designing it.
Another reason is that the chassis is new and Ford probably designed it to last the next 15 years or so, and they probably designed it as a easy way to base a small/mid size RWD/AWD on
Old 02-01-2007, 08:48 AM   #4
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
I thought the tunnel was for the exhaust components, and allowing for the heat to escape.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 09:09 AM   #5
Piotr
Non-Regular Member
The Focus is built on the Ford C1 platform which is designed to run AWD gear. The Volvo V50 is built on the same platform and comes with AWD.
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 11:14 AM   #6
BlackLS
Posts: n/a
The LR platform is C1. LS, 3 etc is on the C307.
EDIT my bad:
C307 is the duratec engine code
C1 Platform is LS, C170 is the LR.
Old 02-01-2007, 11:55 AM   #7
More revs
Also a tunnel gives stiffness to the structure so it's not wasted space.
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2007, 03:52 PM   #8
Uni
bingo.
Uni/.
Uni is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2007, 09:29 PM   #9
Lagom
EDIT my bad:
The LS Focus was codenamed C307 and its platform is called C1 in Ford language or P1 in Volvo language.
Lagom is offline   Reply With Quote Multi-Quote with this Post
