Old 17-01-2007, 07:16 PM   #1
jww_289
Default remote volume control wiring
The remote volume control on the steering wheel has buggered up, the + volume get stuck and the volume keep increasing :
If I turn the radio off at an acceptable level then on again it is OK as long as you don't touch the control, however when it is in this state no buttons on the radio / CD work however if you insert a CD it plays at that voume, so I have 2 questions:
* Do you have to remove the steering wheel to take off the seek / + / - button assembly ?
* As the + button seems to be overriding the operation of the other buttons what wire connector at the bottom of the steering column is related to this as I want to disconnect it as a tempory fix.
TIA,
John......
jww_289 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 07:59 PM   #2
chief
FTF Club Moderator
chief's Avatar
You have to remove the steering wheel to take the buttons off.
Have you changed your cluster? I had the same issue after changing the cluster.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 08:41 PM   #3
au2sw
Blown 5L coming
au2sw's Avatar
u dont need to remove the steering wheel at all. on the sides underneath the control are 10mm bolts, undo these and u can remove the front assembly, then unplug the wiring for airbag, placing it on cardboard face up (static electricity can set the bag off so handle with care) the controls are on the main steering assembly and easy to get to, problem could be as easy as dirt and grime on the pads.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 08:48 PM   #4
jww_289
Thanks guys, I have not changed the cluster, it just happened, I would think it is some crud in there or bent contacts as if I lever the + / - controls away from their backing plate then the volume does not keep increasing and the other controls become operative.
au2sw - can you be more specific about the location of the 10mm bolts, I will go and look now but I can not recall any bolts in that area.
TIA,
John......
Old 17-01-2007, 08:52 PM   #5
au2sw
Blown 5L coming
au2sw's Avatar
u will see a round cut out on either side of the wheel, underneath the volume control and cruise control (if fitted) pop these out with a small flat blade screw driver, and the bolts r under there (one per side)
Old 17-01-2007, 09:06 PM   #6
NC1183
NC1183's Avatar
Aren't the bolts in that area those Anti-tamper Torx ones
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 10:51 PM   #7
TwistedEL
TwistedEL's Avatar
They are a bastard to get off
You can get a $30 kit from bunnings that has a flat blade with a notch taken out of it. It isn't the correct tool but it is suitable. Do not get the similar kit from Dick Smith, I snapped every one of them.
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 10:59 PM   #8
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Or get a flat head screw driver & cut the middle out so it will fit.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2007, 01:05 AM   #9
TwistedEL
TwistedEL's Avatar
The kit is a "security tool" kit it comes with a lot more than just the flat blade with a notch - I should have mentioned that. It doesn't have the 5 sided security torx bit unfortunately.
Old 18-01-2007, 10:06 AM   #10
GK
Walking with God
GK's Avatar
I tried this without a dremel (used a hacksaw) and didn't get it right.
I ended up using my brother in law's security kit ( 6 sided) which included the notched flat blade. I snapped it just at the end of job.
It will do the job fine, if you don't try to torque it up too much. In fact, if I was doing this type of job again, I would take JC's advise, and replace those 5-sided security screws with allen key bolts. Much less heartache next time round.
I did see a 5-sided security key set in an auto shop (opposite MacDonalds in Heidelberg Bell Street in Melbourne) for $40. I was tempted, but didn't get it.
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 18-01-2007, 12:51 PM   #11
jww_289
I found the torx bolts under the cover but will not have time to remove it before Saturday as we are going down to Lorne for a week, my second option was to temporarily disconnect the control at the base of the steering column, does anyone know what connector / wire colors it is or should I just disconnect them all until I have the right one ??
TIA,
John......
