11-01-2007, 11:59 AM | #1 | ||
SOLD: 2006 LS Focus LX
When we start the engine on our LS Focus while not wearing a seatbelt the loud seatbelt warning alarm frequently sounds. Isn't it only meant to beep when travelling over 20km/h without a seatbelt? Does anybody elses car do this? Ford tried to turn it off in the computer but it didn't work. Any comments? Also our car still occasionally pings on 95 octane petrol. Ford say take it back to the dealer but the dealer say there is nothing more they can do and a new flash is coming out soon that may help. Are there many other LS owners that still have pinging issues on 95 octane? When speaking to Ford it would be helpful if we knew how widespread this issue is. Thanks
11-01-2007, 12:07 PM | #2 | ||
Non-Regular Member
The seatbelt warning will sound as long as your don't have seatbelt on.
11-01-2007, 12:22 PM | #3 | |||
11-01-2007, 12:43 PM | #4 | ||
Non-Regular Member
It starts when you put on the key will ring for a little while. Stop and then start again
11-01-2007, 12:48 PM | #5 | ||
Sometime I like to eat lunch in the car and need to open windows etc while doing so. Of course to open windows you have to turn on the ignition - seatbelt alarms ruin a quiet lunch.
I've tried to program the silence code but discovered it was from the previous model so it didn't work after wasting an hour or so. All I do now is push the red seatbelt release button down for 5 secs and turn on the ignition... the car thinks the seatbelt is on. then I can adjust windows for ventilation without scaring shoppers. |
11-01-2007, 01:04 PM | #6 | ||
As for the pinging there are plenty in this forum with that problem but a few like me who have no problem at all.
One thing might work. Reset the ECU then go out an P plate the thing. Mine was thrashed from new. The dealer had just received the car and I was the first to drive it and believe me I rev limited it and gave it a caning not expecting to actually buy the thing. I mean they have "other" cars that customers buy right? Bahhh it was the only black Zetec they had so I had to buy that exact one. Still I kept thrashing it and still do to this day and it's had no problems at all, touch wood. As for fuel all I use is 10% ethanol 95 RON without any pinging at all. I've used 98 RON from time to time but all it does is cost more and frees up slightly more torque below 3500 RPM. I wish Ford would resolve this pinging issue too... |
11-01-2007, 01:18 PM | #7 | ||
2007 Ford Focus Zetec
I thought you could browse through the cluster menu and turn the sounds off?
11-01-2007, 01:21 PM | #8 | |||
11-01-2007, 04:00 PM | #9 | |||
Does this on 95 or 98 RON at times. Seems totally random, can go on for weeks without doing so and then comes back here and there. Kind of surprising considering my other car has a 11.5 (vs Focus' 10.8) compression ratio and never pings. |
11-01-2007, 04:16 PM | #10 | |||
11-01-2007, 05:24 PM | #11 | ||
This is really me :)
Make sure all ya fuel filters air cleaners are clean and that ya spark plugs are still alright cause sometimes if theres **** in somethin it does the strangest of things and dont run the tank to empty too often cause that stuffs ya filter up which then causes problems as well anyways thats enough of me blabbering on
11-01-2007, 06:53 PM | #12 | |||
12-01-2007, 12:08 AM | #13 | ||
My Focus occasionally has a slight ping which i feel is related to the starting issues i have experienced (ie taking 3 or 4 times to start). I have had the fuel pump and sender replaced twice now and still no resolve. The dealership has told me that they have to wait for Ford to get back to them with an update on resolving the problem. So Ford are aware of the issue. I just hope they come up with a solution soon.
12-01-2007, 01:41 AM | #14 | |||
Get ford to run their diagnostic tools on the car to find out what the computer is thinking when the car is being cranked. |
12-01-2007, 08:57 AM | #15 | |||
Black LX Sedan. Classy as... |
28-01-2007, 12:50 PM | #16 | ||
Yes, laminge changed me
Apparently there is a special sequence that you can go through to diable the seat belt warning? does anyone know what it is?
Cheers!! Would love to shut the beeping up once and for all |
28-01-2007, 02:43 PM | #17 | |||
29-01-2007, 10:00 AM | #18 | |||
29-01-2007, 10:11 AM | #19 | |||
29-01-2007, 11:20 AM | #20 | |||
Non-Regular Member
1: Wear your seatbelt 2: Ground the connection |
29-01-2007, 12:56 PM | #21 | |||
Posts: n/a
I was gonna disable the whole speaker when I was doing the dashlights but I realised that id have no blinker tick tock. I'm also a bit weary about grounding the seatbelt buckle due because it may be linked to the Airbag and seatbelt pretensioner systems and may cause a system error. I'll probably give it a go anyways. |
