#61 | |||
#62 | |||
BrwnBstd
Surely, there are more important things to worry about than some spoiled cow who wants a nose ring.. |
#63 | |||
#64 | |||
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
#65 | ||
Wot cheeses me off?
When you buy a car in good faith from a yard. Then you find: *The LPG system is all but stuffed and in need of a new computer *The LPG tank fails the 10 year inspection *The leaking front oil seal takes three attempts to fix it, under warranty *When told that I'm going to get an RAA Inspection done on the vehicle, the dealer nearly has a coronary *The power steering pump leaks *The replacement hydraulic line for the power steering doesn't arrive when quoted *The replacement power steering line is blocked by the contractors' attempt at quickly soldering the joins, leading to the power steering pump crapping itself *The power steering pump crapping itself leads to the drive belt tensioner breaking *The replacement drive belt tensioner is off a different model and doesn't quite clear the drive belt, leading to a series ov lovely grooves being worn into the tensioner *The SECOND replacement drive belt tensioner doesn't fit either *The THIRD replacement drive tensioner does fit, but then the wife has to cancel a day's work because I need the car so I can go to work when mine is getting drive tensioners replaced *The dumb$h!# mechanic leaves the car in reverse when he gets out to greet the dealer and myself when we were going to see what mess he's made now, nearly running the wife over *AND The RAA of SA says that the dealer can take the car to whatever mechanic he likes because he is the one giving the warranty (not exact words, but legal meaning is clear) Beware where you buy your cars in Adelaide. My problems are now fixed, but it cost me money. The dealer would have made not a red cent on the sale after the repairs, however. Hee hee.
Te pilos recidene volo et opus solidus capere ![]() |
#66 | ||
*that annoying person we all know who has ALWAYS done everything you have but even better!!!
*religion!!! *people smoking in their cars with children as passengers *ray martin *people being remorseful for things AFTER they are caught! * |
#67 | |||
#68 | |||
