Old 05-04-2007, 01:51 PM   #1
newdriver
Default Is it necessary to warm engine for 2 mins?
someone told me it's better to keep the engine running idle for 2 mins to heat the oil before run on road, said higher oil temperature benefit to the lubricating effect.
but other said the engine can rapidly heat itself to the required temperature.
which one is correct?
thanks!
newdriver is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 02:02 PM   #2
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
Jump in.
Start up.
Flog the crap out of it out of the car park.
It soon warms up in about a min or so
Chris
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 03:59 PM   #3
FRA
Mr Focus
FRA's Avatar
Originally Posted by fordel
Jump in.
Start up.
Chris
your kidding me.
You should warm up your car even for a few mins.
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody
Oz racing: WRC OBX: 4-2-1 race header
SCT: xcal3, dash scan.
FRA is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 04:02 PM   #4
joe260
joe260's Avatar
yeah i wouldnt flod the crap out of it if its been sitting there overnight.. i always in the morning start my car up leave it running for bout 5 mins til im ready to go and yeah.. i dont flog it til its at the normal temp in between 1/4 and 1/2..
i dont think its any good to just start up and start driving.
joe260 is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 04:52 PM   #5
Piotr
Non-Regular Member
I drive it with revs between 2k to 3k while its cold and only when its at nominal temperature do I rev it to 6.
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 05:07 PM   #6
Ives
Ives's Avatar
Very enthusiastic driver aren't you, Piotr.
I always warm up my car in the morning for 1 or 2 minutes. Here's what I normally do...
-Start the car and let it idle
-Put on shoes
-Drive out
Ives is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 05:26 PM   #7
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
My goodness...
You dont need that for all the new engines.
Mine is warm after 30 secs of normal driving
Get in start up and go
easy as
Old engines, yes warm them up for a couple mins
Old 05-04-2007, 07:31 PM   #8
Sov
Yeah, get in, idle for ten seconds to get the oil up to pressure then drive off and take it easy for the first couple of minutes. Your gearbox or diff oil isn't going to get warm just sitting in the driveway idling.
Sov is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 07:33 PM   #9
Perana
Perana's Avatar
It's actually worse for an engine to sit idling for a few mins than for it to be driven.
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 07:39 PM   #10
FalconXR6
FalconXR6's Avatar
Anyone care to bring fact to this discussion?
I would be interested in the answer too.
FalconXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 10:08 PM   #11
zetec
Zoom Zoom
zetec's Avatar
It goes harder when it's cold. I run harder off the lights when it's cold.
That's fact enough for me
2012 Mazda3 MPS
Old 05-04-2007, 10:21 PM   #12
Stugots
2006 Focus LX Hatch
Stugots's Avatar
Once the gauge starts to move, you're ok to go. I usually keep the revs down though until it gets to about 1/4
Stugots is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 10:24 PM   #13
Stugots
2006 Focus LX Hatch
Stugots's Avatar
That's coz it idles higher with the autochoke plus the cooler intake system means better inducted air density. Gotta take those opportunities
Old 05-04-2007, 10:55 PM   #14
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
You're only meant to let the engine idle for about 15 seconds to let the oil circulate around the engine, but don't flog the engine while its still cold.
You'll do more damage to your gearbox, than you would to your engine.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2007, 11:08 PM   #15
Steffo
LPG > You
Steffo's Avatar
My procedure...
Get in, start car.
Wait for temperature gauge to move from stone cold, turn on A/C, drive away normally. After its popped up a bit... it takes not even a minute to go all the way to normal temp. Process usually takes 1 - 3 minutes.
LPG Lovers Association President & Member #1.
Steffo is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2007, 10:51 AM   #16
scooby
I've read in owners manuals for different makes of cars 1) let engine warm up for 20 seconds 2) don't idle engine for more than 5 minutes.
In the Fez, I let it warm up until the rpm's settle down to normal idle (750 - 800), usually 20 or 30 seconds, then drive off.
scooby is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2007, 11:12 AM   #17
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
I always warm up the car in the mornings for a minute or so. Only because the car is a bit sluggish until its at operating temperature.
But I never over rev the engine when cold. most revs is about 3k while still cold. I just take it easy until car is at operating temp.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
2018 Hyundai Santa Fe Highlander
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2007, 12:47 PM   #18
photn
AFF Post NAZI
photn's Avatar
i turn car on. close house door. get in car drive to end of driveway. close gate. then drive like i normally do.
when i get to end of street. let first gear hit 6k just to get things going!
Old 06-04-2007, 07:47 PM   #19
newdriver
My goodness...
easy as
Is it because new engines apply new technology? or just because its new?
Old 07-04-2007, 12:49 AM   #20
eXtremist
eXtremist's Avatar
I think its more to do with oil pressure.
Old 07-04-2007, 09:49 AM   #21
Perana
Perana's Avatar
It's mainly because new engines are EFi (better fuel metering) and we now have multigrade oils.
The reason to "warm up" the car by idling is because in the past there was only single grade oils that did not work wwhen it is cold. Also some would warm up the engine on a carbied vehicle if it is a pig to drive when cold.
Old 07-04-2007, 02:44 PM   #22
BlackLS
Letting the car idle does not let the gearbox oil to heat up.
Your better off driving it sedately until operating temprature.
Old 08-04-2007, 10:03 AM   #23
newdriver
Thanks, however checked Focus service guide it recommends use of SAE 5W-30 oil, is this single-grade?
Guess my car is using SAE 5w-30
Old 08-04-2007, 07:30 PM   #24
twistedfirey
I hope all you guys revving the crap out of your cars have it paid off before you need a new car... Oh oh I think I'm starting to sound like my old man.
twistedfirey is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2007, 10:16 PM   #25
Perana
Perana's Avatar
5W-30 is multigrade.
Old 10-04-2007, 08:21 PM   #26
zetec
Zoom Zoom
zetec's Avatar
4 cylinders are made to rev. They love it. :
2012 Mazda3 MPS
Old 11-04-2007, 09:47 AM   #27
More revs
Drive sedately like BlackLS said neither overly long idle time or thrash from cold are great for an engine.
Be mechanicaly sypathetic and use common sense
More revs is offline   Reply With Quote Multi-Quote with this Post
