V8 Powaah
Well thats the best way i can describe it.
Does Ford or anyone for that matter, make a steel or aluminium, protection splash plate for underneath the engine on the AU's? My plastic protection plate in addittion to being a pain in the but whenever i wish to drain the coolant, has a tear in it and the 'ridge' is starting to droop. To put it simply it looks **** house. Does the plate actually do anything, because i cant see it providing any decent protection, other than as a splash guard and i cant seeing it being of any aerodynamic use with that big ridge at the back of it. So i debating whether i should just bin it or if someone does make an aluminum one, use that.
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
![]() Join Date: Oct 2006
Ford should have a pressed steel one available. They did for earlier models. Be warned though unless you have tiny fingers you may also need to open up the small hole allowed for draining the oil before fitting it.
regards Blue |
Sorry on checking i discoverd the later model ones are plastic (and more expensive).
regards Blue |
Apparently ... they do aid in the efficiency of your radiator condensor ... have heard it from a number of sources in here and outside the forum as well.
#5 | ||||
Back to Le Frenchy
I better put mine back on then ... although not having an overheating issue any more (for now though ... can't test in hot weather anymore).
twin-core radiator works wonders ... I will do load testing soon though to see how it goes. But on the freeway cruising ... the temp drops at the moment
Monsoon SIII XR8 220
Another thing they do is help stop ripping off your front bar when you (or wife!) park over a concrete kerb like they have in most car parks, it helps the bar slide back over it rather than getting hooked up on the inside edge of the bar when reversing out.
Cheers Sly |
