20-05-2007, 06:37 PM | #1 | ||
hi i am currently putting a 302 windsor into a 78 model te and have herd that the standard water pump will not fit. i am going to be running an aussie desert cooler alluminium radiator. any info on this would be great.
20-05-2007, 07:27 PM | #2 | ||
Heavy right foot
you can use a castlemaine rod shop conversion
which uses a holden six water pump... |
20-05-2007, 07:41 PM | #3 | ||
Hmmmmm Mulberry....
I got a TE 302w with standard water pump. Outlet in passenger side.
21-05-2007, 11:59 PM | #4 | ||
XA GT
use a water pump off an injected windsor, like an "EB falcon" as they have the short snout on them that I think your after, you'll also have to put a different pully on it as the EB one wont suit.
01-06-2007, 08:04 PM | #5 | ||
What State are you in ?, NSW would only allow you to put in a 302 on gas or a 5.0 EFI, not an older 302w on Petrol. (So be careful and check with you rego authority)
I have a 5.0 U.S. spec motor and the pump clears fine. |
02-06-2007, 02:08 AM | #6 | ||
I got a clevo in mine and it fits easy.
What would forum's be without post whoring know it all's......... |
