Posts: n/a
Afterburner + skids =
![]() Join Date: Dec 2004
Like, how quick?
Looks cool!
#3 | |||
It is hard...
Seriously though, that looks pretty awesome, any details?
I could eat a knob at night... |
#4 | |||
Posts: n/a
Whats more you can order a kit, all you need is a donor engine :>
Regards Prof. Rabbit Chassis: Multi-tubular steel chassis frame. Engine: 1164cc Inline 4 cyl., DOHC, with Ram-Air. Transmission: Sequential 6-Speed close ratio gear box, purpose designed reverse gear, rear wheel torque damper. Front suspension: Unequal opposed triangular arms, adjustable dampers with coil overs, sway bar. Rear suspension: Swinging arm, dual adjustable dampers with coil overs. Steering: Rack and pinion (2.25 turns lock-to-lock), leather steering wheel. Brakes: Front discs: Cross-drilled discs, 11in.(280mm) diameter, 4-piston aluminum calipers. Rear discs: Cross-drilled disc, 10in.(254mm) diameter, 2-piston aluminum caliper. Wheels and Tires : Aluminum 7"x16" front, 11"x17" rear, 195/50/ZR16 front tires, 315/35/ZR17 rear tire. Body: Reinforced fiberglass plastic-sandwich construction, carbon fiber windscreens and headrests. Cockpit: Side-by-side 2-person seating, adjustable backs, adjustable foot-pedal box, 3-point retractable safety belts. Dimensions: Wheelbase: 90in(2286mm); Width: 78in.(1981mm); Length: 138in.(3500mm); Height: 42in.(1067mm); Dry Weight: 900lbs (410kg). Fuel Capacity: 7.5 US gal. (28L). Performance: 0-60 mph: 4.1 sec. Top speed: 140 mph. Lateral acceleration:1.9g. Quote:
#5 | |||
Grinder+Welder = Race car
Oh, and I seriously question the 1.9g lateral, you ain't getting nearly 2 g without 4 wheels, slicks and some downforce. It might be an instantaneous peak lateral, but it shure wouldn't hold it on a handling circle.
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear" - Too much power is never enough....Mark Donohue on the Can Am Porsche 917. Last edited by Gammaboy; 11-05-2005 at 12:35 AM. |
