T1 TE50 Galaxy Blue #010.
Location: In between German Engineering and Tickford Perfection.
Put the new rear wing on a while ago and i am left with two stains that run the width of the boot from the double sided tape that used to hold down the old bobtail wing anyone got any ideas what to use to get rid of it, i've tried the tar remover and gave the boot a cut and polish but it is still there..
it is a stain or the glue from the tape as this happen to once and I got this tin of stuff from the sticker place ($8.00) and it took it off with out any damage to the paint but dam if I remember want it was called but I'm sure they will
It got the better of me and looked in the shed and found it try isopar h or sometime called hydro-carbon liquid this done well
not here much anymore
Try something like goo remover or bug and tar remover. Do you have a high pressure hose? If so, give it a pretty good going over with that at a close range but with a wide spurt of water (not just one single jet blast at it). That should loosen it up a bit, then wash it as normal, and some ScratchX or similar should take care of any marks it leaves behind.
RAM 1500
Thanks for that i'll give it a go today and maybe finally get rid of the stains
Afterburner + skids =
![]() Join Date: Dec 2004
Is it a stain in the actual paint?
Speed Kills. So buy an AU XR8 and live forever. Oo\===/oO Last edited by Peuty; 14-05-2005 at 01:25 PM. |
Beware of mood swings!
Location: Western 'burbs, put your bullet proof vests on!
Eucalyptus oil might work. Test it somewhere that's not obvious first though.
1993 EBII GLi Auto, 4.0L MPI rebuilt by JMM, JMM Dev1 kit, JMM Hi Flow Cat, still to hit the quarter mile. :Up_to_som
Dyno Sheet-14/07/05 |
On another note, where's your old wing?
Shoot.
Try "Paint Doctor". You should be able to get it from SuperCrap Auto for about 10 bucks. Comes in a big tooth paste sorta tube. It's bloody magic. Removes scuffs, stains etc..
20V Turbo |
Peuty-- The stain is either side of where the tape used to be all traces of the double sided tape are gone and now just the stains which are dark in colour running the width of boot lid.
LG-- The old bobtail is sitting in the garage, are you interested in it? |
they call me Tibbo
you could try and rub them out with 2000 grit w&D then buff it... It sounds like it is the clear coat thats tarnished.
#12 | |||
PM sent.
#13 | |||
Ahh i see. I had a similar problem when i tool the 4.0 badges off my ol' ED. Fixed it by doing what Racecraft said.
