Old 24-07-2007, 10:45 AM   #1
Boss 330
miss my V8
Boss 330's Avatar
Default Any QLD roadworthy issuers out there?
Hi guys, im in the process of rebuilding my XC fairmont, and the previous owner has deleted the heater pipes that run through the fire wall. Just wondering, is it a requirement to run a heater for a roadworthy or can i weld those holes up aswell?
cheers.
Boss 330 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2007, 10:52 AM   #2
Neeek
65 Galaxie Hardtop
Neeek's Avatar
From previous experience, it IS a requirement that the heater hoses are connected to obtain a legit RWC. The usual practice is to dummy a couple of hoses up to make it look as though everything's hooked up if your heater core leaks (as most do!), although if you find a friendly RWC guy that's prepared to overlook it then it won't matter. This may be academic if you have no way of dummying them up, in which case you'll want to find a leniant RWC guy.
I think that the reason it needs to be connected is so that the windscreen demister works.
Red on red 65 Galaxie 390FE C6 9"
Neeek is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2007, 05:08 PM   #3
Boss 330
miss my V8
Boss 330's Avatar
cheers for that Neek. Ill see what i can sort out, might as well just hook it up properly i spose and be done with it.
