Blue Power Racing Developments The home of Blue Power. Website Link |
I'm in Perth and was wondering where I can get the bluepower intake for my BA XR8?
Cheers. |
#2 | |||
Cheers mate.
#4 | |||
BOSS 5.4L Enthusiast
#5 | |||
KenneBell Australia
Bluepower Racing Developments Proud Australian Distributors of Kenne Bell superchargers The Quickest, The Fastest, The Baddest Boss Blower of all. www.bluepower.com.au |
Professional Mouse Jockey
Is there a trick to installing these?
I recently bought one second hand for my 3V but as far as I can tell there is what I think is an airconditioning pipe in the way down the right hand side (engine side) of where the side of the airbox should sit. Also is the windsreen washer bottle relocated or does it fit inside the airbox? What do you do with the oil breather line that plugs into the OEM intake at the throttle body? Thanks, Paul
Isuzu MUX for towing horses - currently no Fords in the stable Time flies like an arrow; fruit flies like a banana. Groucho Marx
#7 | |||
AFF.com.au
The windscreen washer bottle remains in its location, with the fill tube residing under the lid. The airconditioning pipe needs to be pushed away fom the airbox, it requires adequate clearance or it will wear through. Bluepower 3v kits are supplied with an A.C.E inlet pipe - this has a fitting supplied for the said oil line, however if you purchased your kit from Paul (CVE) he has made up his own system, might be worth PMing him so you get the lowdown on what to do. Chris |
Thanks Chris. It is a CVE pipe; I bought it from sfr rob, came off his 3V Ghia.
#9 | |||
KenneBell Australia
Chris
