Right,
I am in the process of upgrading my desktop, and I have just purchased a ASUS P5K motherboard. I am using my existing case, which is a 400w power supply, and it says P4 compatible. I assumed that this motherboard would accept the same power connection. The connection on my power supply is 20pin, and on the new motherboard is 24 pins. I can physically connect the power to the board, but there is 4 pins on the end that are not connected to anything. These pins are +3volts, +12volts, ground and +5volts. looking at the other pins that are connected there is supply at least once for all the above... HELP PLEAESE
Powered by Rollin Motorsport Turbo Barra ED 4L
All Ford Club Life Member
![]() ![]() Join Date: Aug 2005
No - Upgrade your PSU and do right and you wont have any headaches, $65 should see you right for a decent enough one.
Worked AU XR8 Ute - Toy Std FG XR6T Ute - Daily Supercharged BA 6 Ute - Wife's daily 351W F150 93 XLT 4x4 Supercab |
There should be a seperate 4 pin connector from your PSU.
lpg = big boom!
the standard 20 pin connector will work,
the extra 4 pins are useless at the moment, they are there but never used. as long as its p4 compatible aka has the extra 4 pin connector to go into the 4 or 8 port bit on the mobo it will be fine owning computershop and working in it has tought me alot... they want you to upgrade when you really dont need to ![]()
BF Futura Dedicated E-GAS w/Ghia bling Project: 86 ZL Fairlane, Red, Sunroof, 310,000KM ![]() |
well, its running..
![]() i connected the 20pin and there was an extra 4pin connector which is also now connected. now the long process of formatting 320gb drives and installing win xp pro. thanks for the help. i think i will eventually get another PSU though.
Holy crap with a P5K board I'm guessing you're running a CPU with 1333fsb?
I'd get a new power supply asap. Right now your stressing the outta ya PC. How many Amp's does the PSU have on the +12 section of the table? Also how many rails does it have?
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come! |
lpg = big boom!
if you know anything about electronics and computers....
the "500" watts a power supply gives in not 500 watts. divide it by 1/3'rd and you will get a true measure. if you want something good and reliable get a HEC i have a 750w running all my pc QX6800 2 x 8800GTX 4 x 72GB 15k SCSI 2 x 1TB Hitachi its all the speed, and all the power you can want. the "watt o meter" i have running is telling me im drawing 320w's and thats me coding a dvd ![]()
#8 | ||||
Captain Malcolm Reynolds
And whatever you do, avoid Codegen power supplies :P
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car) Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla Quote:
well, it seems to be running fine... i am not the net again.
![]() its only running at 800mhz FSB at the moment. i will get around to tuning it a little later its much faster than my previous insides... PIII 733, 640MB Ram, 60 + 30GB Drive, 64Mb Video card... This one is... Intel Core 2 2.0Ghz, 2Gb Ram, 2 x 320Gb SATA drives, 256Mb PCI-Ex Video card, blah....
#10 | |||
lpg = big boom!
aopen ritmo omni and about 30 other no-name brands
ok... just to confirm something...
below is a pic of the motherboard. ![]() Near the keyboard connection there is another 4 pin power supply. My current PSU has this connection as well as the 20 pin connection... Do I still need a 24pin connection? I have searched the net, and from what i have read i dont need a 24pin supply, if i also have the extra 4 pin connection... slightly confused.. :(
#12 | ||
lpg = big boom!
the extra 4 pins on the 24 pin psu dont do anything at this stage
just an excuse to sell you a psu when buying a new mobo :-/ it will be adapted, but not yet probally just like the 4 pins near the ps2 ports were needed to a few years go
