Focus Rookie
http://cgi.ebay.com.au/Ford-Focus-Du...QQcmdZViewItem
The seller says it will work for the 2.0 Focus and XR4 aswell.. Any thoughts?
04' Panther Black Focus Zetec Custom Euro Plates, ST side indicators, MK2 Badges, ST Snorkel, White 17"s, Exhaust, Springs, Volant Intake,Angel Eyes, Body Kit, St170 Lower Grill, F/C Throttle Body, DBA slotters |
They are the adjustable cam gears that you get as part of the package if you buy Kent cams. For adjusting valve timing. They are not underdrive pulleys, different thing.
Old enough to know better
Bloody cheap!!!!!
A pair of Kent adjustable cam pulleys would normally cost you roughly US$300. However, the teeth don't look right for a 2.0 litre Zetec. And normally they are light alloy. These look like steel. Still. Bloody cheap http://www.focussport.com/camgears.htm
#4 | |||
And then of course the cost of dyno runs to dial them in!!! A bargain is not always a bargain.
Not unless u set them aside and instal with cams at the same time, which ummm dont you happen to have?
Aaah yes! But I also have the Ford Racing cam gears ready as well. Just waiting to gather the funds to buy a new FR cylinder head...and the funds to get it all installed and tuned. It could be a while
