Old 27-11-2007, 09:57 PM   #1
71CORTYOWNER
71 Mk2 Cortina owner
71CORTYOWNER's Avatar
Smile struts
jus wonderin is there any difference between the 1.6 and the 2.0 litre struts on the mk 2 escort?
71CORTYOWNER is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2007, 07:36 AM   #2
whooligan
whooligan's Avatar
From 1977 the coil spring had a larger spring diametre and bigger seat. Same as Capris/Twin Cam Escort (but no removeable steering arm). The strut top is different, but they are interchangeable. Bugger all difference in spring rate.
If you are upgrading from 1.6 to 2.0lt you just have to retain the strut top from the original car.
Old 29-11-2007, 09:05 PM   #3
71CORTYOWNER
thanx for that!
Old 29-11-2007, 11:53 PM   #4
2lt_Scort
I disagree with the above.
You'll find 1.6 struts have a smaller diameter spring than the 2lt along with a different insert. Top hats are the same depending on when it was made. Earlier Escorts have large strut top, later ones have small strut tops.
Brake are the same.
Mk2 2dr 2lt Escort
Mk2 2dr 1.6lt Escort - now a 2lt.
2lt_Scort is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2007, 01:13 AM   #5
mickas
http://classicford.mine.nu/forum/top...chTerms=struts
mickas is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2007, 01:14 AM   #6
mickas
http://rsmotorsport.com.au/forums/viewtopic.php?t=1112
Old 30-11-2007, 01:14 AM   #7
mickas
http://classicford.mine.nu/forum/search.asp?mode=DoIt
Old 30-11-2007, 09:34 AM   #8
whooligan
whooligan's Avatar
Brake are the same.
Read what I say, then read your response....You are just re-iterrating what I've said.
How can the top hat be the same if the spring diametres are different??? : I think you are getting strut top and top hat (of the spring) mixed up.
Old 30-11-2007, 10:02 AM   #9
2lt_Scort
Whooligan maybe I read what you wrote wrong....re reading it.
I did mean the strut tops are the same depending on when its made (not top hats)
I guess it depends on what Escort 1974 xb falcon has currently. If its already say a 78' model then the 1600 strut top (not spring hat) can be used on 2lt struts. But struts are different. If he has a 1976 model with 1600 struts and wants to put 2lt struts in from a post 77' model then all of it but strut top goes straight in.
Eh....getting to confusing. I think we both know what we mean.
Best bet for 1974 XB Falcon is to follow Mickas links are read up and it should all be clear.
Mk2 2dr 2lt Escort
Old 01-12-2007, 09:12 AM   #10
whooligan
whooligan's Avatar
I think you're right....we've definately confused the hell out of him.
I'd better not start taking about 2lt panel van suspension, or this could go on for years.
