Old 06-09-2007, 10:55 PM   #1
4dlvr
4dlvr
Default lowering car, springs or reset???
wel story goes i was going to get my sucpension lowerd i only want it about a inch, and the guy told me im better off getting them reset...
has anyone tried this??? ive asked around and from what ive herd their better then aftermarkets(kings, pedders) as long as you dont go to low...
some advice plz
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 07:14 AM   #2
FOCUSonTHIS
FOCUSonTHIS's Avatar
I would say buy Eibachs pro spring kit from www.european-parts.net
For about $300 you couldn't complain with that
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 07-09-2007, 11:03 PM   #3
4dlvr
4dlvr
but i only want it a inch or so, i called up a couple places and they said 200 to install so $500 all up. double what ild be paying for reset
atm im trying to find out a little bit about reset suspension, if any one knows about them or has been in a car with reset suspension please let me no
Old 07-09-2007, 11:38 PM   #4
Piotr
Non-Regular Member
Eibach lower 1.4 and 1.2inch. Thats easily an inch or so
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 11:55 PM   #5
melbzetec
Old enough to know better
melbzetec's Avatar
worth a read:
http://autospeed.com.au/cms/A_3082/article.html
Old 08-09-2007, 02:36 AM   #6
BlackLS
If price is a problem even with $300 eibachs, go some $150 Lovells or King Springs.I wouldn't reset a spring personally raises questions about spring strength and unadjusted spring rate(better ride than Kings but bottoms out the susp hardcore). Plus if you ever wanted to bring it back to stock having the unmolested standard spring comes in handy.
Old 08-09-2007, 05:07 PM   #7
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Steve, the info in the link is well worth a read. Thanks for that.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 08:56 PM   #8
4dlvr
4dlvr
thanks 4 that site, im gonna bite the bullet and go for it..
ill post pick after.
Old 11-09-2007, 04:44 PM   #9
whippet_zetec
Supes
whippet_zetec's Avatar
bah hahahaha.........what a loser, oxy torch to re-heat..
Yes I DO drive a Toyota
whippet_zetec is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2008, 05:34 PM   #10
melbzetec
melbzetec's Avatar
4dlvr...........where did you get the $200 quotes from???? I'm interested
Old 04-01-2008, 09:49 PM   #11
4dlvr
4dlvr
it was this place on sydney road, but then i found out the compressd the springs not reset.
i got my ef fairmont done at the suspencion center in sunshine i think. he done a excellent job.
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
