Old 08-01-2008, 11:20 AM   #1
Sterling
Default side stips on doors and quarters.
so im getting a sump off whooligan and then my engine with a good lookover, will go in my escort.
now next is paint and body.. ive already done half the bodywork so its getting close to paint...
now what i need to know is, how do the silver + black strips come off the side of the car? mine is a 4 door 1600.
should i take them off or just cover them for paint?
thanks! :
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2008, 03:29 PM   #2
feral
I always thought side strips like that are stuck on, I could be wrong. If they are stuck on, either push it out in the sun so the panels get hot and therefore weaken the glue and run some fishing line behind them, or get a hair dryer out to heat up a patch. Once you can lift an edge, they should peel off. Either way, if you are going to paint it, remove them and if they are a must have, fit new ones later.
feral is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2008, 06:11 PM   #3
Sterling
do they come off flat metal? cuz i dont want to have to measure where they go on.
Old 08-01-2008, 06:12 PM   #4
Sterling
do they come off flat metal or do they have marks cuz i dont want to have to measure where they go on.
Old 10-01-2008, 04:53 PM   #5
Jimmy-RS
Jimmy-RS's Avatar
I remember taking these side strips off my old mk2 1600....once you take them off, there are no markings as to where they go back on.
I'd reccomend leaving them off, your escort will look better .
Jimmy-RS is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2008, 11:59 PM   #6
Sterling
do you or anybody else have a picture of an escort without the strips?
Old 11-01-2008, 11:32 AM   #7
Jimmy-RS
Jimmy-RS's Avatar
Indeed I do, this is my old 1600 after id removed the strips and polished off the marks from the glue....
Old 13-01-2008, 04:36 PM   #8
Sterling
your right that is alot better thanks!
