Old 28-04-2005, 10:08 AM   #61
Bangers
Posts: n/a
Also, is a diff whine a common problem with the AU(2)'s?
Mine is starting to make a slow whining noise around 2k rpm (highway). Release acceleration and it goes away, full acceleration and engine noise etc makes it harder to hear, but at 2k-3k rpm it's noticable. I'm only assuming it's the diff to...
Old 28-04-2005, 10:20 AM   #62
b2tf
not here much anymore
b2tf's Avatar
Nup, silicone spray is different to WD40. Should be able to find it at Bunnings etc, i think that 'Australia Export' company (the one that makes all the cheap spraypaint) make it, but not sure. Youd definately be able to get some either ther or Repco though.
Diff whine - ive heard of some AU's having it but not many. Perhaps a trip to a diff specialist will help you work out what is causing the noise (if it is the diff).
RAM 1500
Old 02-05-2005, 09:25 AM   #63
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
I bought an ex taxi AU 12 months ago with 748,400 kms. I do preventative maintenance myself. The car has done 42,000 k's in the last year. nothing has gone "wrong" with the car. I have just fitted a turbo kit.
The one cheap fix I would reccomend to anyone - The front end in the AU is said to be good for 300,000 k's, to re-do a front end costs $700 - $800. I bought a second hand front end (control arms, upper and lower ball joints, shocksetc...) out of a wrecked car (40,000k's) for $300, rattle gun and some isolator rubbers and tie rod ends later, you have a new front end for about $360. You will still need a wheel aignment.
I dont like ford service. They once chrarged me $92 for a quote! besides that in my experience they simply replace rather than fix. There are some mechanics who have been around the block (a few times) who will run rings around the dealerships in price and ingenuity.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2005, 01:51 PM   #64
Pete A
Boss 260
Default AU common problems
I owned a AUII XR8 auto for 4 years - just bought BAIIXR8
The AU was generally very reliable - but had a few niggling problems which were mostly resolved during warranty
Noise in rear end when backing off the throttle - slowly got worse eventually changed the slipery diff and OK from then - this is a common problem with the AU's
Sometimes a loud clonk when tranny changes from 2nd to 1st at low speeds - this was a limited factory recall - only if you complained. A new throttle body on the tranny . OK from then.
Rear top shock mounts went - started banging. Changed and fine since then.
Hand brake not releasing properly - they never were able to fix it!
Never broke down on me and got a great price when I sold it privately! I hope the BA is as good as the AU was, but not off to a good start.
Pete A is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2005, 01:54 PM   #65
Pete A
Boss 260
Default Diff Whine
Yes - is is a common problem - mine was replaces at about 40,000 kms - make sure they use the propper diff oil! I believe it's a special kind for those 2000 model diffs.
Old 09-05-2005, 10:37 PM   #66
Steve_T
Pete A, based on your post count, welcome to the forums!
You mention using the correct type of diff oil in your post. Are you saying that most/some of the AU diff problems are actually just caused by using the wrong oil and if so maybe that they don't come with the correct oil from factory? Or were you just mentioning the oil as a side-note to the problem ie. not directly related to it? (I suppose this depends on the diff too now that I think about it - diffenent AU diffs used different types of oil and/or additives. This brings me to ask another question for everyone - which AU diffs were affected by these 'common problems' I hear about? eg. AU1/2/3, just 6cyl diff or 6cyl LSD or V8/XR live/LSD or IRS w/LSD or just all or 'em were bad or what??
As a note, I haven't noticed any problems with mine yet (XR8 ute - LSD live axle). Car is only 27,000 odd kays though. I did dump the factory oil and fill it with fresh SHC ID when the car was pretty new though for what it's worth.
Steve.
Steve_T is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2005, 10:59 PM   #67
Sylox
Uterus M.I.A.
Sylox's Avatar
Mine was fine @ 90k Au2 xr8 ute Mal Wood inspected the gears and said they were in top condition
Sylox is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2005, 09:30 AM   #68
TCK-098
TCK-098's Avatar
Well my first Au was a lemon 99 build 1 tonner seriously when i bought it in july 2004 till the time of its departure in november 2004 it spent nearly every week at cumberland ford for something anyways i told them from day one the T5 that it had was stuffed well when it decided to spill its guts across Appein road at 90kms and turn up barely going they still said that there was no problem.
never buy a ford form there unless you want to be F-------- over,
Well since getting the 98 Au fairmont i have now it has had the CV,s replaced,CD stacker replaced,exhaust,waterpump,thermostat and the car has only 120kms top car as ive driven BA and i reckon they are overated as id prefer my AU anyday.
18 T6 Multivan
03 Ba Xr turbo 300rwkw
TCK-098 is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2005, 08:33 PM   #69
Mechan1k
Mechan1k's Avatar
So far I have noticed the fuel gauge problem on my EGAS AUII XLS.
Only sometimes it will just go dead empty and show DTE - 0 ... but slowly climbs back up to the right capacity (takes about 30 min to do so though).
Has happened a few times ... once after stopping really hard ... strange ... other times it just shows empty when starting ... I turn the car off and then on again .... and it rights itself.
Old 18-05-2005, 10:41 PM   #70
MrAUII
MrAUII's Avatar
Problems I have had with my AUII 2000 are:
Welsh Plug at back of block behind gearbox leaked coolant quicker than I can pee. Cost of part was $3, labour hundreds as gear box had to come out too. Replaced all 6 steel plugs with brass and while everything was out and apart all seals etc were replaced. All up $800.
Shockers absooutely screwed
Rotors completely warped but i do play footy in the hills.
Little clock in dash the numbers stop displaying 100% and only could see bits and pieces of number.
Steel frame piercing through seat.
The door locks are another problem. When you press the lock button on remote a door doesnt lock but you hear the lock motoring. Well something is stufed and ford charge $200 then what happens two days later another door goes.
MrAUII is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2005, 11:27 PM   #71
Timeshift
Timeshift is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2005, 02:19 AM   #72
TCK-098
TCK-098's Avatar
yay just got rid of my tickford springs as car sat to hi to my liking and put in some king springs anyways IRS yay top shock mounts are kaput.
18 T6 Multivan
Old 11-06-2005, 08:19 PM   #73
richo77
richo77's Avatar
how do you know when your mounts in your rear shockies are finished? I think mine are on their way out, i'm hearing a knock over bumps which sounds like the boot lid isnt closed properly or the spare wheel is loose (its neither)
do you reckon this would be covered under ford's extended warranty?? i would think they would be but wouldnt be too surprised to hear that they arent!! :
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2005, 04:16 PM   #74
Timeshift
The good old "wear and tear" excuse... my money is on that they won't.
Old 19-06-2005, 05:02 PM   #75
DJM83
Barra Turbo > V8
DJM83's Avatar
its good to have so many answers to our probs ive had my car 2 wks luv it only it has a rough idle problem also i think we need to start a forum on Venom AU XR's cause there seems to be a few
2011 XR6 Turbo Ute
- Manual
- Lux Pack
- Twin 2.5" Stainless Exhaust
- Antz Turboside Intake
- CCForged Phatlux wheels
- Tuned by LS Tuning and Performance
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 19-06-2005, 06:35 PM   #76
kiwi
Default checking for stuffed rear strut mounts
Fold down your rear seats. Where the metal hooks stick out to latch the seat back there is some christmas tree clips holding back a carpet cover. Rip those out (They are cheap to replace if you wreck them) and expose the top of the strut. Put your finger on and top and give it a wiggle. You will hear your clunk.
kiwi is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2005, 03:29 AM   #77
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Originally Posted by TuffEDXR
ialso i think we need to start a forum on Venom AU XR's cause there seems to be a few
Yes you are definitely right. : I'll put that down as a common problem with the AU - there isn't enough of them. :1syellow1
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2005, 09:53 PM   #78
richo77
richo77's Avatar
well your nearly right... i took it to ford and they looked at.. the invoice says "check for rattle going over bumps - add washer to rear shock mounts - road test and advise owner'... result: F'all difference, in fact i think it got a little bit worse.. back she goes..
one good thing about this extended warranty - they are replacing the high pressure line in my power steering which is leaking (the solid metal line not the rubber one).. i'm told its a $400 part................
Old 20-06-2005, 10:01 PM   #79
Timeshift
Yeah that sounds like good ol' Ford. Do something to give the impression that they are attempting to fix a problem when it does nothing to help the deeper issue and give you the runaround with multiple visits.
Re: Power stearing - so they bloody should :
Old 20-06-2005, 10:11 PM   #80
richo77
richo77's Avatar
yea its a fun game and we all have to play by their rules if your stuck in the warranty sham.. i think i shocked the service advisor when i said 'i think its the rear shock mounts' when i took it in.. jaw dropped and then a scowl as in 'dont tell me my job'. i love this forum!
Old 20-06-2005, 11:17 PM   #81
Timeshift
He probably assumed that you are like the 99.9% of people who get their car serviced at Ford who know how to check their oil and radiator and that's it
Old 12-07-2005, 11:36 PM   #82
bdmat02
Posts: n/a
I have a 2000 AUIIs. The shocks feel very hard on rides. Can hear clanks when i go over a bump and all my body parts are thoroughly shaken.
Is this common with sports suspensions or does it need to be fixed.
Also my indash CD player is gone. Doesn't like any CD. Tried all kinds of random combination. Had a problem for an yr before it gave up. It is easy to replace the player with another off the shelf unit
Suggestions?
Old 13-07-2005, 02:39 PM   #83
Bangers
Posts: n/a
I get the exact same thing. 2000 AU2 forte.
I'm curious whats the cause/reasoning for this, as when I get my suspension done very soon, (koni sports, king ssl) I don't want to find that my entire cabin rattles and shakes bad due to a poor build quality.
Old 13-07-2005, 04:08 PM   #84
slim
If the Konis are adjustable wind them down to minnimum stiffness,mine were set too hard and flogged out the top shock mounts way before you'd expect them to wear out
slim is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2005, 05:59 PM   #85
MrAUII
MrAUII's Avatar
Suggestions?
Sounds like the shocks could be stuffed.
AUII Forte 4.0L - AUSOM3
Audio Visual Incar Entertainment
Old 31-07-2005, 09:54 PM   #86
buckshot
130,000 km later um er nothing wrong, gone wrong, and hopefully nothing will go wrong
buckshot is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2005, 05:06 PM   #87
fipcee
not so stock
fipcee's Avatar
Talking
AUIII, XR6, 76k, had it for 3 months now. Going well, due to take back to.."dread" Ford to get her service. My problems are diff whine low down, annoying but getting used to it, and the main one is that when I accelerate hard (I have to get across 3 lanes of traffic in the mornings) and turn right it feels like there is a "locking" at the rear right of the car. After getting across the traffic and turning and accelerating nothing much happens (really feels like a massive brake lock) until I put the boot in to it and then there is a big "bang" and all is fine. This has happened 3 times and I am certain that it aint good. Does any one have any thoughts on the problem? I really want to be armed for when she goes for her service and to date this is the best place to get info from that I have ever encounted. People are honest and there are no hidden agendas. Thanking ya awl in advance
Liquid silver AUIII XR6, BA scuff plates with Tickford inserts, proudly displaying AU falcon.com stickers, lowered, K&N panel filter with wide mouth snorkle, 2 1/2 exhaust and hi flo cat, Illusion mags, slotted and drilled rotors.
Next mods: extractors
fipcee is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2005, 05:15 PM   #88
fipcee
not so stock
fipcee's Avatar
Oops sorry to all. I have just read the first post by Casper that stated this is not a " I have a prob what is the cure" area me. Therefore if any one has had the problem I mentioned in my previous post I'd love to know what u did to fix it. :nutsycuck
Old 03-08-2005, 12:00 AM   #89
FAIRMONTAU2
Fipcee my AU2 beam axle had a 'diff whine' turned out to be the dreaded noisy NCT5 tyres. Swapped them over and it mysteriously went. Just a thought, but the other problems definatly sound diff orientated. The diff may need the pre loads adjusted.
FAIRMONTAU2 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 06:41 PM   #90
sammiles
Posts: n/a
Suggestions?
I have an auII also. I was having the clank sound over bumps etc and just assumed it was shocks/struts so I took it to brakes plus and they were gonna charge me some ridiculous amount and I didn't have enough cash to get it done so I took it down to my mates burson and he ordered parts and took it to a local mechanic and he told me it was all fine what actually needed replacing were the engine mounts. Cost me $150 to get those done. No more clunking sound.
Stock cd player sucks. Replace.
