Old 21-01-2008, 02:31 PM   #1
vandrsxr6
Force Fed Fords
vandrsxr6's Avatar
Default Metal Fabrication
Need a bit of help.
I need a couple of parts made up for my car, some bracing(?) pieces about 300mm long 20mm wide and about 3-4mm thick.
Can anyone recommend someone who could do this? Must be someone in Melbourne, SE Suburbs if possible.
Thanks Joel
BA XR6 TURBO
310rwkw and always chasing more
Now with 6th Gear
RAPID PERFORMANCE
ORSM FORD CRUISER
vandrsxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 04:18 PM   #2
boxo
fit 'n' turn
boxo's Avatar
Hey mate i work for an engineering workshop in clayton. Draw up a sketch of what you need done and im sure i could help you out.
You can have the material at cost and a slab or two for me depending on the size of the job.
Box
It's not always enough to do your best,somtimes you have to do whats required.
boxo is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 04:33 PM   #3
vandrsxr6
Force Fed Fords
vandrsxr6's Avatar
Box
Thanks mate, I'll drop you a PM next week some time, when I get my car back.
BA XR6 TURBO
Now with 6th Gear
RAPID PERFORMANCE
ORSM FORD CRUISER
