Old 12-07-2008, 09:01 PM   #1
BTTB
Free XD
BTTB's Avatar
Default Lopping the roof off - legalities
Not sure exactly where this kinda question belongs
I have an old '65 Galaxie 4door sedan
It was purchased originally for a RHD conversion for a hardtop
Its been stripped of its trim, badges, and glass (all sold off)
the door trims, seats and steering wheel are missing
I do still have all the front panels and grill/lights
And I was curious about the legalities of hacking off the roof as far as rego goes...
I'm assuming this kinda thing requires engineering certification before rego ???
but being a full chassis car which doesn't differ much from the factory convertibles I don't think it will effect rigidity at all
It would become a dedicated convertible with no retractable roof (and stored in the garage during inclement weather)
Apparently the factory '65/'66 convertibles just had an extra crossmember in
the separate chassis near the back... which shouldn't be to hard to fab up...
But do I need to have windows in the doors?, or can i weld up the tops of the doors too and lop off the window frames
the rear parcel shelf would be filled in too
A small block v8 and auto on LPG would suit cruising during the warmer months
I was just thinking of making basic door trims and maybe some fibreglass mouldings for kick panel/pillar areas
Are there any other things I should consider ?
BTTB is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2008, 09:50 PM   #2
podderick
podderick's Avatar
talk to an engineer ,he should be able to set you straight with what is needed re rego worries and issuing the right papers for the roof lop
1993 eb2 falcon dual fuel
and my other car passion 1970 vw baja project
podderick is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2008, 09:54 PM   #3
Silver Ghia
Silver Ghia's Avatar
Even though it may have a chassis, the body and especially the roof would have a big effect on the torsional rigidity of the car as a whole. The chassis itself would have relatively low torsional rigidity, so I think it would be necessary to reinforce the chassis substantially for this reason.
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 13-07-2008, 12:23 AM   #4
Sourbastard
Contributing Member
Sourbastard's Avatar
Shame you arent in SA. as its Pre ADR you could cut the roof off it without even an inspection.
1965 XP Falcon Deluxe Sedan
1978 XC Falcon Wagon Rallypack
2003 BA Fairlane G220
Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM
Sourbastard is offline   Reply With Quote Multi-Quote with this Post
