Old 10-08-2008, 06:33 AM   #1
Biggs
Default Jacking Points
Is it safe to jack the car on the "rubber seat" directly below the springs? Would it be able to support the car's weight?
Photo is taken from the rear underchassis of a Mazda 3 which is more or less the same with the Focus.
Biggs is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2008, 11:38 AM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
I've always found this link useful.
http://www.focushacks.com/index.php?modid=74
I wouldn't use that particular point to support the car.
Old 10-08-2008, 01:13 PM   #3
Mullett
Badly Focused
Mullett's Avatar
It'll support the weight, for sure, but DO NOT go under the car, or even close, because it'll be extremely unstable. If you're using a screw jack, use the factory jacking points, if you're using a hydraulic jack, I'd try the plate between the two suspention arms, and put jack stands where the factory jacking points are...if you're going to be under the car, make sure you've got jack stands...plenty of people have lost arms or worse from failed jacks...it's only an Oring holding 1000kg from coming straight down...
RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2008, 08:11 PM   #4
BlackLS
yum
RM.
Agreed, the $40 hydraulic jack from Repco lifts the wheels only just off the ground at this point.
2005 LS Focus LX
Nov05 | Manual | Black Sapphire
250,000kms.
BlackLS is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2008, 10:43 PM   #5
Mullett
Badly Focused
Mullett's Avatar
Block of wood is your friend
RM.
Old 11-08-2008, 03:25 AM   #6
Biggs
That link is spot on! Thanks! I guess this means that an H-type lifter cannot be used for the Focus.
