Where to next??
While waiting for my dad to finish work I went over to 2 middle aged ladies in some sort of Suby. The bonnet was up, and they were looking under there while one was on the phone.
I asked what the problem was, and they said the battery was dead, and the NRMA was on the way. I didn't have access to jumper leads. Their car was parked on a slight incline, facing up the incline. Sooo.... can you clutch start a car in reverse same as you would in 2nd gear rolling fwd?? I know reverse gearing is a lot shorter than 1st, so would the car come to life then take off uncontrollably like a bat out of hell?? Not that I will come across the same situation again lol. Jason ![]() |
yes.
done it plenty of times in the past when i used to have a celica, a flat battery and a steep driveway. |
certified nutter
yeah you can do it no worries, done it in my festi and other little cars too
BF XR6, oh yeah!!
Yeah, saw a bloke in a Commodore do it the other day, and my neighbor used to do it all of the time with his old POS Astra.
Current ride: 2005 BF XR6 Sedan, Lightning Strike, ZF Auto Previous ride: 2001 AUII Futura Sedan, Narooma Blue |
#5 | |||
Yes, I have done it a few times in the XE I had out of the short, steep driveway where I was residing a few years back. Only need a little speed to turn the engine over with the short reverse gear. The same would apply if you were facing downhill and chose 1st to turn it over.
Once you feel it fire, clutch back in, make sure it keeps revving and drive normally from there
Yes, but when it starts going like a bat out of hell, remember to use clutch and brake to solve new problem. LOL
Silhouette BOSS302, Just as The "Good Ford"Made Him |
Temporary Australian
yep, msot certainly can, my work ute (96 deisel hilux) has a POS electrical system, it needs to be jumped daily, so we NEVER park it on a flat. once we did, so we needed to jump it, and walaahhh jumped in reverse! doen it a few times now!
Where to next??
Haaaa ok no worries then. I may just practice it in the Festi myself when I have nothing better to do lol
Cheers, Jason |
im pretty sure your not ment to do it in reverse.... tho it can be done... but im sure someone once said to me that there is a possobility of winding the engin over backwards...
#10 | |||
#11 | |||
Flairs - Truckers Delight
I don't know whether bnsuteau or ken2903 are kidding, because the motor doesn't change its operation no matter what the transmission is doing. The motor doesn't care! the same direction of turn comes out of the flywheel no matter what your trans is doing. Mate of mine used to do it in his LJ Torana all the time. No probs at all.
Yes i was kidding lol.
(hence the italics) |
#13 | ||
oh sorry, i'm sick, my brain isnt working quite right.
do you think bnsuteau was kidding?
#14 | |||
Will an engine rotate backwards if your car is in reverse but rolling forward (on a steep hill i guess) with the engine off? surely something in the gearbox would let go first? and if it was on a giant treadmill would it take off? kidding ![]() |
#15 | |||
moderator ford coupe club
obviously if it is neutral or going in the correct direction for the gear, it should not be a problem |
#16 | ||
Yeah the T5 in my BA feels like its made with paper mache, chopsticks and a big **** rubber band so i won't be trying any hill starts in either direction or gear
#17 | ||
did you pay extra for the chopstick reinforcement?
i'm curious now, and it's doing my head in. if the engine did manage to spin backwards, with the ignition on... would it then start rotating the other way using the exhaust valve as intake and the intake valves as exhaust? imagine the damage that would cause. this is what happens when you work night shift and wake up at 1.30pm and read threads like this. |
#18 | ||
No Car Too Low Too Tow!
you can start any manual car in either 1st or reverse (could do damage in rev), even when its stuck in gear and clutch is gone just to move it around just have to turn off to go back or forward
If it goes like a Zirtec, Why am i towing it? |
