#31 | |||
#32 | |||
#33 | ||
I can understand that ramming in air is better, but if its lacking up front (smaller snorkel), it will suck in front the lower part of the box like there is no tomorrow im sure
Things to remember though - you "cant" compress the air like this so you will be restricted by the pipe size from the box to the Throttle Body and the Throttle body size itself. Even worse - like me soon - if you have gas, that is how you will be restricted - by the size of the mixer ring so going a pipe that's 125% larger than the mixer is a waste |
#34 | ||
I wonder if you can get a bit of a bigger gas mixer ring (as long as you make the induction bigger) - that would help?
#35 | ||
Ford beginner
There would have to be something out there. It wouldn't make sense to have an LPG system and be limited by the air intake. Even playing field!
#36 | ||
if you get a bigger mixer it is harder to adjust idle and low rpm settings. the reason being that, the mixer needs vacuum reference, the less resistance the air passing over the mixer, the less vacuum created. that's why they invented svi, for one, to get rid of the restriction. if you have a look in the lpg section, there are people trying to sort something out for a variable venturi mixer, this basically means, the middle can move to let more air through under high rpm, to reduce lean conditions as standard mixers run out of flow.
so, to summarise that, no, you can't have a bigger mixer. if you don't want a restriction, you better get svi or lpi. if you want to keep your mixer because it is cheap to fit, then don't expect to get the same gains as people only running petrol. just remember, lpg is to save money, not make your car go faster at the same time. if you really want more performance, forced induction is the way to go |
#37 | ||
good point.
I think I may just add my K&N Panel filter and mod the box a little as per the above drawing ![]() |
#38 | ||
Tickford Man
Thanks alot lads, you have been very helpful and this is a great help to me. I went to autobahn the other day n the guy behind the counter told me that this brand called 'DRIFT' produce more power in air filters compared to k&n filters,
Which filter do you think I should go for and is this info true? |
#39 | ||
Ford beginner
I have always heard K & N are reliable and worthy of the coin. Never really looked into much else, trust what is trusted I guess!
#40 | ||
Tickford Man
Yeh i generally go with whats trusted but the guy did say it won't last aslong as the k&n. But the DRIFT product must good because I saw about 3 guys leaving with one each in their hands and they had high performance cars..
#41 | |||
#42 | |||
![]() Join Date: Jan 2005
#43 | |||
Narooma blue XR8 ute
#44 | ||
AFF Whore
The other day I made a 40 x 40 square cutout at the front of the airbox to see if would make any difference and was quite disappointed.
well today I took the plunge and widened the cut to a 100 wide by 75 high piece out of the front of the airbox as Monty had suggested..... all I can say is WOW! The low-down power has improved greatly and the sound is so much deeper. And to think it only cost me almost cutting my fingers off with a jigsaw ![]() very impressive gain for quite little |
#45 | |||
Tickford Man
Lol, that sounds good.. I'm probably going to give this a go on saturday! What car did you do the 100 x 75 cut out too? |
#46 | ||
AFF Whore
AU Series 1 Fairmont Ghia with the VCT motor.
I'll post some pics tomorrow, looks rather dodgy as I didnt have anything to secure the airbox with as I was cutting it. |
#47 | ||
Tickford Man
ah well, doesn't matter.. as long as you got the job done and it was effect that's the main thing!
#48 | ||
[ 5L ]
you will find a greater difference david, more air is let in through the xr lights than the normal lights
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
#49 | ||
AFF Whore
#50 | ||
GOOD WORK
I was looking at doing it from the fender side to ensure warm air wont get to it. You obviously find that there is enough airflow being a non xr light set up? |
#51 | ||
AFF Whore
surprisingly enough yes, I was also concerned about warm air but so far the power gain seems to be fairly consistent. the real test will be summer
#52 | ||
ty - I will then look at doing the same
#53 | |||
Tickford Man
#54 | ||
Tickford Man
Well finally got all my intake done! I bought the k&n panel filter today and also cut the box out on the front..
The whole note of the engine/exhaust changed and performance is much better.. much deeper note now! Here's some pics of the cut out I did: ![]() ![]() |
#55 | ||
love the xa's
you know how some race cars have some type of pipe or tubing to the brakes to allow cold air to help cool down..(i hope that made sence) can you add something like that to vent cold air to the box from the front somehow?..so heat isn't the only air sucked in??
#56 | ||
Flairs - Truckers Delight
well done grandpa spec au, i'll have to drop round in the next week or two to check it out.
#57 | |||
Made the 300 :0)
New Owner of a fiesta ST |
#58 | ||
No-one should be to concerned or take any company too seriously when they start flogging their 'RAM' air intakes. To make any use of ram air, it needs to be compressed, which you'll find just about impossible below 200-250km/h. The performance gains that come from any of these intake mods is simply increased volume of airflow.
