Had a good search through the forums but found nothing relevant. Hoping someone can help me.
Have a Fairmont AU with the CD stacker in the boot and a remote amp behind it which, I believe, drives the back shelf speakers. About two weeks ago I started to lose sound intermittently from the back speakers - would turn the car on and the speakers would be working, drive for about 10mins and then silence. This continued for about a week but for the last week I have had no sound at all. I have checked all plugs into the back speakers (sub in the middle) and they are all sitting correctly. The amp is powering up fine and both the RCA leads are plugged in correctly. Can anyone shed any light on where the problem is? Is it the amp and if so how do I get it out to check it? Do I have to drill out the rivets that hold it in or is there an easier way that I'm missing? Yours hopefully |
Smile
Did you check the earth to the amp?Sometimes with age and heat they may simply need a clean. Failing that ..pull out your radio and check the connector going in for the amp.If you get stuck let me know here in this post.It is a process of elimination. If I were there I could find the fault in 10-40 minutes .On the net obviously I cant see the car and will take a bit longer.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
Miami Pilot
![]() Join Date: Jan 2005
My olds had this problem in their AU2 Falcon - well, a similar problem as their whole radio would stop working intermittently. The CD or whatever would still play, but no sound came out. I swapped the radios between my AU2 and theirs, and all was good in both cars for about a week, but then they went to Melbourne and the radio/CD stopped working on the highway. It worked for the whole return trip though.
I had a look at it when they returned, and the only thing I could pickup was that one of the rear speakers sounded a bit distorted when the radio did work, so I replaced the rear speakers and they have never had the problem again. After pulling the rear speakers out, I obviously checked them, and the speaker cone had started to tear away from the body - I have no idea why this would kill all 4 speakers, but by replacing the faulty speaker (and it's mate) it has definitely cured their problems. So....you could give that a try - I would suggest replacing the front speakers with a decent aftermarket pair (even the base Aerpro 5 X 7s at around $25 a pair are better than the standard stuff ford fit), and then put the fronts in the back. Even if this doesn't fix your issues, it won't have broken the bank, and you will have at least one pair of better speakers. Another way to diagnose the problem would be to run some speaker wire to the amp, and to a set of speakers you know are working - even old PC speakers will do. If you get sound by doing this, you know that either the speaker wire or the rear speakers are at fault.
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, HSD/ShockWorks, black GT335 19” staggered replicas with 245 & 275/35/19 Michelin Pilot sport 5s Daily: BF2 Fairmont Ghia I6 ZF, machine face GT335 19” staggered Replicas with 245s and 275s, Bilsteins & Kings FPV 335 build stats: <click here> Ford Performance Club ACT Last edited by JC; 13-08-2005 at 10:20 PM. Reason: spelling |
First, thanks for the replies guys.
To Useless, yes I have checked the common earth (attached to the post that the amp is riveted on to). Removed it, gave it a quick clean and re-attached it but still no sound. As for removing the head unit well..... tried that with the old coathanger trick - unclipped three sides and then managed to break the clip on the last one :(( Think it might take a bit of dash removal to get it out now. Would certainly appreciate any other advice you might have though. To JCXR8, unfortunately I'm on the nightshift so just reading this from work for the first time and therefore unable to try running some wire to another speaker. Will give it a go when I get home though. One question - and I hope this doesn't seem too stupid - but should I be connecting the speaker to the RCA inputs on the amp? Sorry, quite the beginner at this. As for replacing the speakers, its something I'm hoping to avoid to be honest. I'm unimpressed by the sound quality from what is supposed to be a 'premium' sound system but I'm, really not very handy at that sort of thing. Thanks again guys. |
#5 | |||
Miami Pilot
As for the "quality" you would expect from a factory system - when they use $2.50 , paper coned speakers, quality goes out the window in the interests of profit margin.
#6 | |||
Yes id have to agree on the quality of the ford so called premuim sound set-ups talk about house so i threw all the speakers out and repalced with fusion best thing i did and the CD stackesr well they are good enough for frisbees ive had my car for 9 months and im up for my 4th stacker.
FFS ford is wish they would make a decent sound system for once ![]()
18 T6 Multivan 03 Ba Xr turbo 300rwkw |
buickman
I've only replaced the door & rear deck speakers on the AU1 ghia for better quality sound but have not had any problems with the stacker in the boot.
But have heard many stories on the dash stackers on the AU 2/3 playing up a lot. buickman |
#9 | ||||
XR6 and XR8 Club of QLD
Panda
Car - Ford Falcon XR6 Turbo |
#10 | |||
Hope thats a bit clearer |
