17-09-2009, 10:24 AM | #1 | ||
Hey everyone I am looking into option for rebuilding the motor in the Ghia.
Now this will sound stupid as but is it possible to remove the VCT from a VCTI6? From all I have seen on hear there are no real cam options for the VCT motors so I am looking at the possibility of removing the VCT to allow for a bigger cam. Now the obvious easy way would be to swap the head for a HP head but (and this is so ) I really like the look of the little tickford badge on the front of the VCT head. So is there a way I can retain this head but not have VCT. Maybe HP motors cam into VCT head???? Thanks in advance for ya help gents. |
17-09-2009, 03:09 PM | #2 | ||
You would need to swap to a non-VCT ECU and possibly engine bay harness as well.
Given the differences on the front of the head though, I reckon you'd need to swap the whole head over, not just the cam.
17-09-2009, 07:05 PM | #3 | ||
As far as swapping ecu's when down grading as such, would this really be required? Couldn't the VCT ecu just be flashed to suit?
17-09-2009, 07:39 PM | #4 | ||
^^^^^Thats exactly what I was thinkin.
It's really a case of will a HP cam fit in the VCT head? |
17-09-2009, 07:51 PM | #5 | ||
or have you thought of investing in learning or getting a cam designed for a VCT head??
so you can utilise what ford gave us..
17-09-2009, 08:00 PM | #6 | ||
Yeah great idea. Trying to find a cam that the VCT doesn't over ride is the problem
from all I have ever read on here. |
17-09-2009, 08:03 PM | #7 | ||
from what you have read what does the VCT actually do when it kicks in?
as far as im aware it just advances the cam to a spot that moves the powerband UP the rev range.. so you could go a monster cam that will be streetable down low due to retardation then go ballistic up top
17-09-2009, 08:10 PM | #8 | ||
My understanding is that if you put a bigger cam in the vct simply over rides it.
Now if this is the case can it be over come. There has to be a way. |
17-09-2009, 08:17 PM | #9 | ||
how would it over ride it?? it is a mechanical device that moves the cam forward or backward(in a rotational direction)
as far as I can work out its only "switched" on and off via the ecu at XYZ RPM??
18-09-2009, 05:58 AM | #10 | ||
I am well aware of how it works. Thats not what I am asking.
As stated everything I read says no point doin a cam. VCT over rides any cam modifications. If you can show me proof of an after market bigger than standard cam working or you know how to over come this issue than please do. |
18-09-2009, 06:42 AM | #11 | ||
This is obviously a problem with any VCT motor regaurdless of what it is.
I found this while searching for answers this morning. So is there such a thing for the I6? BBR VCT CAM LOCKOUT |
18-09-2009, 02:07 PM | #12 | ||
there was somebody in the b series or 6 cyl forums, i cant remember which, but they were using a ba engine in a superstock car (or something) and had done cams but had disabled the variable cam timing
maybe something similar could work on the au vct? im not sure what or how they did it but might as well check it out, i will try and find the thread
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
18-09-2009, 02:11 PM | #13 | ||
here you go...
http://www.fordforums.com.au/showthread.php?t=11271276 "the motor is stock apart from i am adding a set of .500 lift cams to it with adjustable timing gears which are being made as i will not be using the variable timing." might have to give him a pm he is still using the forum
18-09-2009, 02:24 PM | #14 | ||
Critical Thinker
Just do an edit. It will feel like you had a cam put in.
I know Jim Mock do cams for VCT also
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
18-09-2009, 02:33 PM | #15 | ||
Thanks heaps static. Pm sent to him so will be interesting to see how he has gone with it.
19-09-2009, 12:51 AM | #16 | |||
i have seen people get in excess of 140rwkw with the usual mods and a vct engine... again different dynos etc... but i do realise the point of your car is to MODIFY it! but the question about JMM that practically asks itself... why do they have an aftermarket cam available when no one else does? surely someone can make one that will run it properly!
19-09-2009, 06:54 AM | #17 | ||
I have to say I am tempted to just get some monsterous cam
ground for me, throw it in and see what happens. |
19-09-2009, 09:35 AM | #18 | ||
www.sctflashtuning.com
get the car flash tuned and turn the vct off if you want or tune the engine and adjust the vct to get more gains it would be better than putting a hot cam in the engine
Australia's No1 Ford Enhancement Specialist 103 Northgate Drive Thomastown VIC 3074 Phone: 03 9464 5100 Fax: 03 9464 5166 |
19-09-2009, 09:43 AM | #19 | ||
have you guys experimented at all with the SOHC VCT motors/cams Herrod??
i guess if sombody can get the specific information on how the VCT operates we could then look into what way to get a cam ground to suit etc ?? I know you can get cams for the XR6Ts etc and hell even the SR20 and RB25/26 motors have more aggressive cams available (yes they are turbo and DOHC but thats beyond the point) if the cam you got ground from a billet was of a spec that fitted where you WANT the specs to be once its kicked over(after the advancment occurs(if thats all it does) then I don't understand how there could be ANY problem?
