Old 28-06-2009, 05:48 PM   #31
leakey
leakey's Avatar
I dont believe you can turn it off.
But, the computer works in sequence. 1/. you open the door, 2/. you turn on the ignition - which makes it beep. It knows you entered the car via. the drivers door.
Now you could get in via. the passenger door!!!! or if it is so annoying, rewire your door switch so that it is hooked up to the passenger door switch. The car will never know you're getting in via. the drivers door. As a circuit is still in effect, the PC should still function OK. (ie door is open warning etc, and interior lights)
Personally I think it would be easier to just put your belt on! My '08 LT does not have this issue however, so I might not know what you're going thru!
leakey is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2009, 10:43 PM   #32
smee323
Yes it is mine...
smee323's Avatar
There is a sequence to turn it off, but alas it has not worked for me, neither did the auto window up..
I have done the auto door locking, an the single open when unlocking.
smee323 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2009, 12:01 AM   #33
rand0mn00b
did you do that yourself or...
rand0mn00b is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2009, 09:17 PM   #34
zetec
Zoom Zoom
zetec's Avatar
No the sequence is for LR. Doesn't work for LS and onwards.
Auto window up is easy. Just close the window and hold the switch up for 2 seconds. It'll then auto-up next time. Has to learn where the closed position is to teach the anti-trap it's boundaries. Needs to be done after any battery repalcement.
2012 Mazda3 MPS
Old 09-07-2009, 11:02 AM   #35
dave_vic_ozz
I have been finding stuff to fool the Computer for a while so we can street legal the AWESOME motor in other cars.
But this will make your cars non compliant with ADR's so don't keep it disabled.
http://www.oz-clubbies.com/forums/in...ndpost&p=56047
Hope it helps
Dave D.
Still looking for Focus front hubs and uprights.
dave_vic_ozz is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2009, 05:46 PM   #36
marg99
Guys, Noticed that if I put the indicator on before turning the ignition on the seatbelt warning does not start and turning the indicator on cancels the beeps after you have turned the car on, assuming you have not yet put the seat belt on. (At least it does on my 2007 LT hatch!)
Old 28-12-2009, 08:57 AM   #37
rattus18
Has anybody actualy tried this ? http://www.oz-clubbies.com/forums/i...indpost&p=56047 .
I just did a number of times, yes the light flashes as stated but it certainly didn't deactivate the stupid chimes. ??
rattus18 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2010, 01:09 PM   #38
takai
Tried this on my LS the other day, and it didnt do anything... :(
takai is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2010, 03:36 PM   #39
tce
BA WAGON
tce's Avatar
Has anyone tryed this one it is for the falcon but might have the same affect (same computer?)
Originally Posted by p1mpdout
easy 7 step process to turning off the seat belt reminder when you start your car, but havent buckled up yet!
1st - hop into your vehicle and shut the door.
2nd - put your seat belt on and put the key into the ignition.
3rd - turn the key to II (on)
4th - press and hold the hazard button located to the left of the cluster.
5th - unbuckle yourself (while still holding the hazard button down)
6th - buckle yourself back up again and release the hazard button.
7th - start your car and then unbuckle yourself...
you should see that your seatbelt light doesnt come up on the dash..
there u have it, no more seatbelt annoying sounds..
i probably dont recommend turning it off as it is there for safety, but god doesnt it get annoying!
--to turn it back on, just repeat step 1 - 7. should turn it back on--
cheers guys...
Shockwave GT-W. lowered, tints, premium sound
tce is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 08:32 PM   #40
ghettomonkey84
Found an interesting read on the sequence needed to disable the belt minder alarm here:
http://www.myfordfocus.com/ownersguide.htm
Doesnt work for my 07 LT LX Focus tho...worth a shot anyway
ghettomonkey84 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2010, 04:58 PM   #41
mrbaxr6t
mrbaxr6t's Avatar
my wifes' new focus does this, doesn't seem to annoy me as much as it does some of you guys? if it really does annoy you that much belt up b4 car start
Phantom, T56, leather and sunroof BAmk1 :yeees:
Holden special vehicles - for special people
mrbaxr6t is offline   Reply With Quote Multi-Quote with this Post
