dose anyone know where i can get a world cup cross member from apart from the uk for a mk2 escort ?
Rally Nut
you can get them from
http://classicescortparts.com.au/ind...category_id=31 try here for one off the shelf I should ask what you are using it for as they aren't that hard to fabricate if you are handing with a welder & grinder, mine took me under a day ![]() ![]() cheers Last edited by Puzzlescort; 06-01-2011 at 10:47 AM. |
Just wondering, what are the pro's/con's with the world cup cross member? is it "legal" for on road use? cheers
Rally Nut
the pros simply are they secure the motor a lot better than the standard unit limiting movement
the cons - they tend to vibrate the car a lot more, transferring the harshness as some put it thru the rest of the driveline are they legal?? I am not expert on that apart from saying all the standard mounting points are used....no modification to body work etc you would need someone very very switched on to even question one as they look like some standard fitment engine mounts |
Im putting a yb cosworth in my mk2 so just wanted some added strength to the set up hence the use of a world cup cross member cheers
