While I was driving yesterday my car just cut out. I pushed the accelerator right in and still nothing while it was rolling. A couple of seconds later it cokes back to life and turns back on. I still had just under half a tank of fuel too. It does it while in going in a straight line and around turns. Any idea of what could be causing it? I just changed my spark plugs and leads if that helps and also my fuel filter around 2000kms ago.
Matt
Au xr6: tickford kits, tickford 17s, momo T Bar and wheel, leather, lowered on ultra lows, 2.5" cat back with hot dog muffler, K&N panel filter and loving the car as a P plater Future mods: 19" staggered wheels Clear side indicaters. That is all |
meh.
![]() Join Date: Jul 2010
coil pack.... check that
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
How do I check if that is screwed?
meh.
umm.... an auto sparky should be able to throw it on a tester... or you can just pull all of the plugs and leads, and ground the spark plug and just crank the car for a second to see if spark comes out... if there is spark on all 6, then the coilpack is fine... if no spark on a 1 or more spark plugs, replace your coil pack with a good working one (can be from EF or AU1/2/3) and see if it runs better
Can I test it with my brothers testers as he is a sparky? I hope it's not the coil pack. How much am I looking at if it is?
meh.
yeah, you can.. its better to get a sparky to test it as they have the better equipment..
and not much... i got a replacement one from the wreckers for a grand total of $5 for the EF... the car was going to the crushers with an AU3 VCT engine unfortunately so they just asked for $5 for the coilpack and i was out of there..
So it's probably not worth going for a new coil pack is it? I mean if it's that cheap gues I can't complain
meh.
If you want a long lasting one, yes, get a new genuine bosch or whatever brand they are coil pack... go to bursons and they should have a new genuine one
i only got mine cause ive spent over $5000 at those wreckers and the fairlane i got it off was going to the crushers anyway.. so it was just a good break for me
rexnet
think you'll find their about $140 off flea bay.
also if you have a SCT X3 cal flash tuner you can bring up the codes and it'll tell you if your coil pack is good or not. |
Confused lil guy
Or have look on US sites like JEGS and buy new aftermarket units like this for same money
![]() Can't remember off top of my head if these are DIRECT replacements or not but wouldn't be hard to get them to fit |
Rob
Chuck some new fuel in from a different servo, bad (dirty) fuel will make the car cough and splutter and cut out, id be trying that before spending any money at an auto elec.
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
#13 | ||
Thanks for all the help fellas. Yeh I'll try shell petrol this time round and see how I go and then I'll spend the money and get myself a new good coil pack.
Much appreciated guys
#14 | ||
Rob
Lets us know how you go
#15 | ||
Will do mate
#16 | ||
Ok so I've tried another tank and it still does it but mostly when I'm turning right. I only use BP petrol in my car nothing else.
#17 | ||
Racing improves the breed
I had exactly the same problem you described when I had my old VCT engined XR6, mainly when accelerating after turning a corner. Turned out the fuel pump sock was loose
1970 Mini Cooper S Historic Group Nc Touring car 1964 Mini Cooper S Historic Group Nb Touring car 2024 Subaru Outback Touring XT Victorian Hill Climb Championship |
#18 | ||
Thanks mate I'll have a look if it's loose and report back
