27-11-2009, 07:00 PM | #31 | ||
What's the best oil for a TDCI?????
04-12-2009, 03:59 PM | #32 | ||
Speaking of TDCI, whats the go with their oil filter cartridge? Whats the procedure to change the filter on a TDCI?
04-12-2009, 06:26 PM | #33 | ||
The castrol web site recommends CASTROL EDGE SPORT 5W-30
for the 2007 -2008 model TDCI but if you have the Particulate filter in the 2008-9 model they suggest CASTROL EDGE SPORT 0W-40 |
07-03-2010, 02:06 PM | #34 | ||
Did an oil change on our LT Focus yesterday. Used Valvoline Durablend 5W-30 semi synthetic oil this time.
The oil sump drain plug was a b*tch of a thing to get off though. Stupid Ford mechanic must have had gorilla arms when he did it up at the 3000km check and oil change. Next time the car's in for a service i'm going to mention to the service advisor to make sure they don't weld the bloody drain plug to the sump! |
12-03-2010, 02:03 PM | #35 | ||
Thanks "mohit"
I did oil change using your step by step guide. Just one thing though. The Focus manual shows different points for jack stands. It seems to me that you put jack stands under engine's handles. Personally I followed manual's advice on placing jack stands which is near the jack on both side of the vehicle. |
12-03-2010, 02:17 PM | #36 | ||
Mohit, the sump drain plug might of been tight from Factory, not when the mechanic did the 3,000km check. Just a thought yeah? As I am a Ford Mechanic, some of us aren't Gorilla type haha.
Also, I must admit the Focus is a pretty easy car to drain the oil, another thing for you. If you don't want the oil to drain over your hands when you undo the oil filter, get a screw driver and a hammer, and line the screwdriver up under the middle of the oil filter, and hit it with a hammer to puncture the oil filter to drain it out through the hole. Might help some of you. |
12-03-2010, 09:22 PM | #37 | |||
12-03-2010, 11:14 PM | #38 | |||||
As long as the car is securely supported without damaging any under car areas you'll be right. Quote:
14-03-2010, 10:55 PM | #39 | ||
It's interesting that the LT service guide doesn't include an oil and filter change at the 3000 km service. You must have paid extra for that. I can't imagine the dealer giving you a freebie.
14-03-2010, 11:28 PM | #40 | |||
From memory it was $70 for an oil and filter change at the 3000km check for our LT Focus. |
26-03-2010, 02:43 PM | #41 | ||
formerly "3x-puursui7"
The mrs XR5 got oil and filter changed at the 3000km "complimentary" service, which also included finishing the pre-delivery ie; removing the travel stops from the suspension! I specifically asked for the oil change at that time but I think its normal procedure anyway, also got the filter back when it was done to inspect for anything scary looking!
all hail the mighty V8's http://www.aufalcon.com.au/3x-puursui7 |
08-04-2010, 11:52 PM | #42 | ||
Just some more on jacking points for the Focus LS/LT/LV:
Firstly, I stumbled across this a while ago on the net, it looks like it is from a workshop manual: However, side-lift points are not always practical and there are some alternatives when using hydraulic jacks and jack stands that I have come across. The following pics are kindly 'borrowed' from the XR5 forums, backing up the jacking points that mohit selected: Jacking points: Jack stand points (as per Mohit's Mazda 3 pic) |
28-10-2010, 08:09 PM | #43 | ||
A good thread, has anyone got information/Pictures on changing oil on a TDCI focus. Used to have a go on my old car, and I would like to have the same know how with this car.
03-01-2011, 03:43 PM | #44 | ||
Quad Cam
I checked Ryco's web site and they list a different oil filter for the LT series, a Z632. LS is still showing as a Z418. LV is a Z632 also.
03-01-2011, 10:50 PM | #45 | |||
FWIW, i used a Z418 LS filter on the LT without any issues. Makes sense as both the LS and LT use the same Motorcraft AFL4 factory filter. |
04-01-2011, 12:18 PM | #46 | ||
Quad Cam
Yep its just plain weird, same factory filter but now ryco list a different one for both the LT and LV. It makes me wonder why they saw fit to make the change, as far as I know the engines are identical.
12-01-2011, 08:34 PM | #47 | |||
I don't think it would matter which filter you used Part Z418 Height Overall 89.00mm Inside Diameter Top 0.00mm Inside Diameter Bottom 0.00mm Outside Diameter Top 0.00mm Outside Diameter Bottom 0.00mm Seam Diameter 77.50mm Seal Diameter 71.20mm Thread 3/4-16-UNF-2B Part Z632 Height Overall 86.00mm Inside Diameter Top 0.00mm Inside Diameter Bottom 0.00mm Outside Diameter Top 0.00mm Outside Diameter Bottom 0.00mm Seam Diameter 77.60mm Seal Diameter 71.00mm Thread 3/4 -16-UNF-2B |
12-01-2011, 09:14 PM | #48 | ||
Old enough to know better
Here are the jacking points for the LR Focus
Courtesy of Focus Hacks
01-03-2011, 04:58 PM | #49 | ||
Just for the need of an empty container you dont want to dump the oil in the engine over its capacity. Its ok if oil level is a bit low but its not ok if oil is a bit high. Excess oil in the engine causes more damage to the engine than less oil. Its a total misconception that filling a couple of 100ml oil is good for engine.
There were few debates on oil grades on AFF before but the fact is there is a reason behind an oil recommendation. When engine is cold started thin oil gets easily into cams, all thin and narrow places easily reducing friction and wear and tear and being fully synthetic it wont break down at high temps. No matter how good the oil is synthetic oil can not be replaced with ordinary oil. Non synthetic oil breaks down easily at high temps. I always go with the recommendation and using a grade above wont kill engine instantly or shortens engine life drastically. It depends how you use the car, right next to freeway and you start your car and jump on to freeway instantly every morning then yes it does make lot of difference with oil viscosity. Again end of the day its your choice. There are many ways of doing things as long as you know what you are doing. Sticking screw driver is not advised with all filters. If a filter has thick deep thread inside then you might damage the it. And if you strip filter using screw driver and filter is still jammed in then you just made your job complicated. Use correct wrench or tools, metal expands when hot and makes it hard so let it cool down a bit. Draining oil overnight would make your engine absolute dry and next time when you fill oil and start, it takes a while before oil reaches all parts of engine and until then its metal on metal. When an engine is rebuilt all parts are lubed before assembled to minimise the wear and tear in the first start. Instead of draining overnight do the next oil change before schedule. Same applies with engine flush. If engine is too dirty and you flush it then you are actually cleaning the deposits on the oil rings and then oil starts to get through the rings. Am just sharing my knowledge and opinion being a qualified mechanic. No offence guys. cheers Yogi
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can. Now driving a Lexus RX 450h. Your guess is correct that I am a family man now. |
01-03-2011, 06:04 PM | #50 | ||
Good contribution Yogi.
I'd give you rep points, but the icon seems to have disappeared
21-03-2011, 12:06 AM | #51 | ||
Could REDDYZ explain what problems are caused by slightly overfilling an engine with oil. I have been guilty of that one.
21-03-2011, 02:17 AM | #52 | |||
Also excessive oil creates air bubbles in the engine which is not good for lubrication and might be hard to believe but if you put too much oil that could blow the engine. cheers Yogi
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can. Now driving a Lexus RX 450h. Your guess is correct that I am a family man now. Last edited by REDDYZ; 21-03-2011 at 02:29 AM. |
14-04-2011, 09:38 PM | #53 | ||
I just noticed that i have been using a ryco Z63 oil filter for about 15,000Kms as picked out and ensured by an autobarn rep that it was indeed the right one for my Ford Focus 2007 (Duratec).
Have i caused any damage? I was running fully synthetic oil (Castrol Edge Sport 5W-30) at the time if that makes any difference. (Remember being told jokingly that you don't even need oil filters for synth oils as there is no mineral "junk" floating about) The correct one for my car is in fact the Z418, here's some comparative pics of the two. As you can see the z63 is much longer/taller than the z418. I honestly don't know how i didn't notice the difference when i was changing them out in the first place.. perhaps i overlooked it due to the filter being disguised in oil as it sat to drain..
2007 LT Focus Zetec Hatch -Lowered on King Springs Super Lows 50mm -20% Tinted Windows All Round -K&N Pod Filter -XR5 Rims (Late Model) |
14-04-2011, 09:42 PM | #54 | |||
i should really learn to read through these threads first before relying
14-04-2011, 11:29 PM | #55 | ||
To clear things up:
LR Focus: Ryco Z63 LS Focus: Motorcraft AFL4 Ryco Z418 LT / LV Focus: Motorcraft AFL4 Ryco Z632 |
14-08-2011, 12:25 PM | #56 | |||
Rob
do the filter up until rubber seal makes contact and then only 1/4 -1/2 turn more. that is plenty. with 12mnth service intervals, the filter comes off by hand. could still need a bit of 'oomph' but no drastic measures are required. |
29-10-2011, 09:50 PM | #57 | ||
You can call me Chris
quiet angry today! Went to do my first oil change on the focus (have previously been taking it to the dealer) Up on the ramps, slide underneath, sump plug has been tightened by hercules and is mostly rounded... Didnt want to risk taking it off without a replacement plug. off to a mechanic it looks, just impossible to remove!
'06 LS Focus Hatch -2 1/4" Lukey Exhaust -RDA Slotted discs/Greenstuff pads -Rear Whiteline swaybay -Lenso 18's w/Kumho rubber -Tinted Windows |
29-10-2011, 10:42 PM | #58 | ||
Use more muscles
29-10-2011, 11:59 PM | #59 | ||
Haha, thought I was going to POP a vessel I was trying that hard!
30-10-2011, 01:36 AM | #60 | ||
If you try again and get it, put some oil on it beforehand and well don't tighten it with 100nm of torque
2010 LV Focus LX Titanium Grey - K&N Apollo CAI - 2" Cat-back Exhaust -18" Black with machined front RS rims - DRL/Halo Headlights - Eibach prokit springs - Front Strut Brace - Black XR5 Spoiler Plans: Whiteline Rear Sway bar |
