Boss 335
Do emissions gear on modern motors help performance or hinder it? If one was to tune up, for example, a current Ford i6 NA, with no regards for emissions whatsoever and all emissions gear removed, how much power would it be realistically chasing? Weren't cars back in the 60s and 70s pulling some figures that would rival todays emission-controlled motors?
Huge amounts, at least 1,000,000kw......
XY GT 351 made just slightly more power than a standard FG I6..... |
Ich bin ein auslander
I think you would find that the ECU would have a fit because of some of the sensor inputs that would be out of whack.
Growing old is compulsory, growing up is optional! |
#4 | |||
I totalled my XR6
Cruising...
Well back then they pulled jack all power compared to today. Exhaust systems and air intake systems are the only restrictors that make any difference.
Make the car breath in and out easier and you gain power and efficiency, but nothing overly spectacular.
FBT '98 BA XT '04 F100 4x4 '82 Subaru Outback '02 |
The ECU controls the car so much better now and gets the air fuel ratio's to just about spot on. However - the ECU is made to be safe so no engine damage will occur - say the intake air sensor pick up very hot air the ECU reacts by adding more fuel in to make it richer (and therefore stop your pistons from melting and your valves burning). Same when a MAP (Manifold absolute pressure) picks up low vacuum - add more fuel to make it safe. The richer the air fuel ratio is the less power you make.
Apart from tuning perameters, the only real emission nasties we have are the cat converters which create a flow restriction on the exhaust. The unburnt exhaust nasties are burnt on the superheated catalyst to stop all those carcenagenic substances poluting the world. Removing the Cats will probably make you 10 kW's on some cars but the $50k fine for doing it isn't worth it.
Official member of the OCMD Club "Semi - Silhouette" 2003 BAGT #514 2007 GT500 factory supercharged motor built! Sensation Blue 2011 FG GT-P # 101 KPM Streetfighter Monster 5.2lt MMR short motor / Stage 3 MMR heads / Boss 302 Exhaust cams FR20 Simmons / Tein Coilovers / Eaton Tru Track / Very scared 305/25/20" Nitto Invo's ZF fitted with a NIZPRO Stage 2 input shaft & Excedy Clutches http://www.fordforums.com.au/showthread.php?t=11408502 |
i think pollution gear severely affected 74-78 cars as the period between the regulations were more restrictive until the makers sorted out how to get power with them.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
#8 | |||
The problem was that the engine designs of the time (clevos and carb I6s) were rather primitive and inefficient and had to be "bandaided". It was not until electronic fuel injection and later improvements in valve timing technologies were deployed into mainstream that the power and torque increased while the fuel usage and emmissions decreased. |
Flairs - Truckers Delight
flappist i think you and aussie muscle just said the same thing, albeit his was less legible and more open to confusion
#10 | |||
Boss 335
#11 | |||
Tribal Elder
Performance moderator
![]() Join Date: Feb 2005
These days they require the pollution controls to make them run right...
Even taking the cat off doesn't [really] make more power...
#13 | |||
Go leaner than stoich and you start creating more heat which eventually ends up in engine damage
