Old 14-10-2005, 11:40 PM   #31
Mechan1k
Mechan1k's Avatar
I have seen this done ... it's not good for the motor.
Also don't stand over the can the petrol is in while the napthalene is in there ... it'll knock you out ... it's strong when mixed.
I will block engine internals ... increase combustion chamber temps ... cause detonation ... kill your motor literally.
Also will screw the filter for the in-tank fuel pumps too ... clog fuel lines.
Seriously ... don't do it.
You'll be up for a new motor.
Old 15-10-2005, 03:14 PM   #32
Kryton
Kryton's Avatar
maybe you should read the actual thread first before you reply.
as for increased temps, over 150km have been done so far and the temp gauge hasnt moved one bit.
no real noticeable performance gain yet, but damn does the zorst sound meaty now!!
Old 15-10-2005, 05:00 PM   #33
Paxton
Cobblers!
Paxton's Avatar
The Episode is on Discovery NOW. For Digital subscribers - Channel 630.
-Andrew
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2005, 05:02 PM   #34
FordFan86
meow
FordFan86's Avatar
While your testing things, can you put a bag or two of sugar into your tank? I'd be interested in the results, thanks.
FordFan86 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2005, 10:59 PM   #35
Kryton
Kryton's Avatar
i can tell you straight off the bat, it does nothing.
Myth Busters put it to the test, even left it sit over night and it didnt do a thing.
Old 15-10-2005, 11:32 PM   #36
Mechan1k
Mechan1k's Avatar
Your temperature gauge tells you water temp (wherever the temp probe is located in your cooling system) ... not internal combustion chamber temperature ... so there's no real way of telling. Unless you have pulled the motor apart and inspected the internals after usage.
Old 25-10-2005, 02:17 AM   #37
Kryton
Kryton's Avatar
ok. out dated update:
the zorst sounded better. a damn lot better!
fuel econ didnt change for that tank. this new/clean tank of fuel is considerably less.
at the end of the tank, acceleration had studders when cold.
still having cold acceleration troubles but getting better.
does moth balls give you more performance?
no, but youll get a better exhaust note!!
Old 25-10-2005, 04:57 AM   #38
Biggoggs
Rider on the storm
I'm no tuner or mechanic, but wouldn't you have to advance the ignition timing for it to have any effect?
I know what you mean by the sound though, every time I fill mine with premium I swear it sounds deeper, but I can't figure out if it's just my imagination.
Biggoggs is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2005, 06:40 AM   #39
Mike Gayner
Mike Gayner's Avatar
Erm, if combustion temps are higher then of course water temp will rise.
Mike Gayner is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2005, 07:09 AM   #40
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Sounds like a great experiement.
Nothing ventured nothing gained.
TURBOTAXI is online now   Reply With Quote Multi-Quote with this Post
Old 25-10-2005, 08:58 AM   #41
RED_EL_XR8
RED_EL_XR8's Avatar
Originally Posted by TURBOTAXI
Sounds like a great experiment.
That's what Bourke & Wills thought too!
RED_EL_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2005, 09:04 AM   #42
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
HA HA HA HA I am related to Wills!!!!!!!!
Old 25-10-2005, 09:07 AM   #43
RED_EL_XR8
RED_EL_XR8's Avatar
at this point I'm not saying a word! :
