hello all,
As the title says. Doing coil packs, plugs, leads, oil and filters. Anything i should be looking at whil im there? Doing CAI soon down the track so ill do a MAF and TB clean when i do that. What oil is recommended? cheers
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
rexnet
Mainlube suggest a 10w60 oil.
when was coolant replaced what color is brake fluid. also im in your neighbourhood and going drag racing next sat ![]() |
not here much anymore
Everybody is probably going to give you different answers as to what oils to use but my barrow gets the following:
Engine Oil - Liqui Moly Leichtlauf 10w50 Plugs - NGK BPR6EFS-15 (i think - whatever the 304 VT 5L runs I use) Filters - all K&N Gearbox Oil - Castrol Transmax Z Diff - Castrol SAF XA Coolant - Tectaloy Gold Brake Fluid - Penrite DOT4 MAF cleaner- quick squirt TB cleaner - quick squirt Other than that I usually tighten up all the header bolts at every service and also give everything a good once over. At my next service I will be fitting 322mm brakes and new fluid and also trying an engine oil flush that Liqui Moly make. Going to put new plugs in too. If you do plugs expect a headache with #5 cylinder - use the plug socket with a shifter instead of a ratchet.
RAM 1500
Synthetic for these engines,no thanks.
rexnet
really? why so Gilly. interested to hear this.
#6 | ||||
rexnet
lol norrie and playford they do that? on the strip
