29-10-2011, 07:13 PM | #1 | ||
3..2..1..
basically, my au3 forte
has been getting close to 500kms to a tank of petrol for the last couple of months, i dont take much notice of what i put in it, e10/95, doesnt seem to matter which, no significant difference. but the last two tanks of fuel ive struggled to get 250/300, both tanks were from seperate servos. its running as averagely has it ever has. its always had a weird miss at idle, and sometimes its a bit lazy off the mark, but its been like that since i got it so i doubt that its the cause. really the fuel economy was one of its few redeeming qualities... without that i doubt it will survive much longer. any ides on possible causes? |
29-10-2011, 07:43 PM | #2 | ||
Next upgraded Mk1 Leopard
Have you changed your normal routes?
UK
29-10-2011, 09:10 PM | #3 | ||
not here much anymore
all the usuals - coils, plugs, leads etc. Maybe 02 sensors. AU's are a fickle bloody thing, they seem to let go with no warning.
RAM 1500
29-10-2011, 11:15 PM | #4 | ||
ROCKING THE EL FUTURA
clean the throttle body change plugs and leads also clean the air filter.
its letting you know everything needs a clean.
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
29-10-2011, 11:28 PM | #5 | ||
here you go
http://www.fordforums.com.au/showpos...9&postcount=43 http://www.fordforums.com.au/showpos...2&postcount=48 clean these first mate i used to do it every month as routine and never stopped getting the 500's to the tank..
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr Last edited by au11futura; 29-10-2011 at 11:55 PM. |
30-10-2011, 12:03 AM | #6 | |||||
3..2..1..
ive been meaning to throw some new discs and pads at it for ages now, has that dreaded warped disc steering wheel shimmy, so i might just order new plugs and leads/coil at the same time, spend a weekend doing some maintenance on the old slapper. |
30-10-2011, 12:09 AM | #7 | |||
[SIGPIC][/SIGPIC]
30-10-2011, 12:17 AM | #8 | |||
3..2..1..
31-10-2011, 06:47 PM | #9 | ||
sounds like a replacement is in order then. have a look at this http://www.ebay.com.au/itm/FORD-Falc...item231599e1c9
[SIGPIC][/SIGPIC]
22-11-2011, 03:11 PM | #10 | ||
Was this problem fixed?
