Old 13-12-2011, 07:30 PM   #1
SIMBAD
RAPID GT-P
SIMBAD's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This thread: BA-BF diff cradle removal for diff bushes
Default Max ellery or gregorys
Hello people, just wondering what workshop manual would you suggest is the better one?
I've heard one is better than the other?
Full Difilippo big boy exhaust /4.5" body ballistic metal cats / boss 315 plenum & twin throttle body coupled to bpr airbox / powerbond underdrives / herrod 290 cams / malwood opt 3+ / hrs Pegasus rims 19x8.5 front - 9.5 rear / nitto invo 245-35-19F & 275-35-19R / whiteline swaybars/ Under bonnet bling / 4.11 harrop truetrac
Enhanced by BLUEPOWER
supercharged 363 dart takes on au work ute http://fordforums.com.au/showthread.php?t=11342906
SIMBAD is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2011, 07:34 PM   #2
fat4D
Default Re: Max ellery or gregorys
i use the Gregory's and cant remember a time its let me down
Now Ford-less
But good things are coming in 6 months
fat4D is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2011, 07:41 PM   #3
Psi-Pop
on the way to the RSL
Psi-Pop's Avatar
I have both, I think the Max Ellerys is a bit more in depth.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9"
8.9x@160mph+
Psi-Pop is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2011, 09:10 PM   #4
Ford_The_Win
Gregories has better pictures, is more model-specific and much better for the home mechanic. The Elleries ones are far more detailed and technical and assume you already have a fair bit of mechanical knowledge.
2011 FG XR6 Sedan
Ford_The_Win is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2011, 09:13 PM   #5
Geez Louise
Awesome
Geez Louise's Avatar
Location: In my own little world..Everyone here knows me :)
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind the scenes things that help the community.
I use the Gregory's one too. Much easier to follow.
Geez Louise is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2011, 09:16 PM   #6
TheyDontWantMus
TheyDontWantMus's Avatar
the Max Ellerys is pretty much useless.
TheyDontWantMus is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2011, 09:25 PM   #7
b2tf
not here much anymore
b2tf's Avatar
I wouldnt go this far but I do agree that Ellerys seems to expect you to know how to do half the job before you start. I find it a bit frustrating in that regard.
2024 F150 XLT
Old 13-12-2011, 09:30 PM   #8
Silver Ghia
Silver Ghia's Avatar
Best to have both, then bits that you can't follow too well you can read up on the other and vice versa, to get a better idea on how to do it.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2011, 09:31 PM   #9
TheyDontWantMus
it doesn't actually instruct.
it has incorrect technical information.
its full of spelling errors and typos.
Old 13-12-2011, 09:31 PM   #10
Psi-Pop
Psi-Pop's Avatar
Yeah that's true, get both. Use the greg to understand what the basics are and use the Ellerys for when you need the detailed information.
You can rebuild a BTR using the ellery you cant with Greg.
8.9x@160mph+
Old 13-12-2011, 10:35 PM   #11
mik
mik's Avatar
agreed, definatly have both, you will find at some stage one or the other will be short of that little bit of info you need..
Old 13-12-2011, 10:41 PM   #12
zdcol71
zdcol71
zdcol71's Avatar
I've got an Ellery's that tells me it's a Cleverland.
(And aside from the spelling, it is verrrrry vague)
: 30 years later
zdcol71 is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2011, 12:48 AM   #13
mik
mik's Avatar
one of the things i found between the 2 in the au falcon version of both was, if you look up auto trans rebuild in both books, ellerys did a reasonable job of a step by step guide (up to a point), in the gregory`s there was basic serviceing and incidentals, but it did not have the rebuild section.
Old 14-12-2011, 07:33 AM   #14
LTDHO
The one and only
LTDHO's Avatar
Neither, buy genuine Ford.
I have tried each on older models and found they were next to no help.
Tuned by CVE Performance
Old 14-12-2011, 08:35 AM   #15
charles_wif_xf
Purveyor of filth
^ What this man said. I had the Max Ellery manual for the XF and whilst helpful by and large, it was far from complete.
charles_wif_xf is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2011, 11:10 AM   #16
big_landau
gregorys are much better imo,having said that i have factory manuals but never use them with dirty hands thats what the gregorys ones are for.
big_landau is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2011, 08:05 PM   #17
fordman302
fordman302's Avatar
I would agree whilst expensive and cumbersome the ford ones are the ducks guts
fordman302 is offline   Reply With Quote Multi-Quote with this Post
