Old 03-01-2012, 01:23 AM   #1
JamesFordFutura
QUEENSLANDER!
Default Slow warm up any time of the day
Hi there, I recently bought a 1998 Ford Futara Auto with 178, 000 K's. When I start the car up it can take up to 10 minutes for the car to warm up and only when I'm driving will it eventually warm up. When I come to a stop and the car is still cold it come times stalls and/or will not take off. I have tried changing the petrol pump I even changed to premium fuel.The gauge starts on cold then goes into the normal area, but it doesn't have to be in the morning it can be in the middle of a HOT day and it will happen. the car will start up every time but then will take a while for the gauge to get into the normal area. When it's on cold the car stalls when i stop at lights etc, or will take of really slowly if I pump the gas. ( it's an auto ) Does any one know what I can do?
I drive hard, I drive fast. Is there any other way?
JamesFordFutura is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2012, 06:05 AM   #2
XDV800
Default Re: Slow warm up any time of the day
Mate, you dont need all these topics, put it in general tech ONLY.
Take it to a mechanic, because you obviously know nothing about Eseries cars, and they will be able to assess it quicker and accurately.
It could be any number of things. Sounds as though your cooling system is fine, it may need the plugs checked, carbon clean, etc. etc. etc. etc...
XDV800 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2012, 09:17 AM   #3
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
It's most likely your thermostat jammed open, either that or the sender unit in the block is stuffed....
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2012, 09:23 AM   #4
Jim Goose
He has issues with stalling etc.... a thermostat stuck open and a "cold" motor wont cause stalling and hesitation when trying to accellerate... (Poster has started several threads in different areas)
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2012, 09:39 AM   #5
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
the stalling part could be something simple like the throttle body needs a clean, or the isc needs a clean.
or a bad connection in the spark plug leads or coil, once it is warm im presuming it is fine.
some dielectric grease could be used in all the electrical connections, to see if it helps.
it may even need the timing to be checked or reset?
and might be worthwhile to reset the computer too while you are at it. disconnect the battery for 30 mins (if you have the radio security code to reprogram it.)
the slow to warm up part could be that there is no thermostat fitted, or it is stuffed and stuck open.
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2012, 09:39 AM   #6
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Replace the fuel filter and air filter...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2012, 10:31 AM   #7
prydey
Rob
prydey's Avatar
is it using coolant?
head gaskets were reasonably common on e series. if thermostat is stuck open the car will take forever to warm up but generally it will just keep getting hotter. it won't just take forever to get to normal and then stay in normal, it will keep going.
