Old 20-01-2011, 01:49 AM   #1
NO2
Old Man
Default Sudden coil failure after service
My 2004 Focus was in for an A service and no faults or problems were found. However on leaving the car had a miss come in under load.
When the car was returned to the Ford dealer we were told that the coil had failed and need to be replaced. $400 later the car is good with a coil and spark plugs replaced.
Considering that the car did not have this problem prior to the service I am wondering what actions would cause a coil to fail like that. Running the car with a lead off a spark plug and not earthed perhaps. But I am not an auto electrician to know the answer.
Ford are adamant that a coil can go at any time but I have trouble accepting that it was purely coincidence happening after they had been under the bonnet.
NO2 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2011, 09:23 AM   #2
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
Without checking a service schedule, I think there is no tuning or coild removal as part of an A service, it is only a minor service.
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2011, 06:49 PM   #3
fordmondeoman
either bad luck or more than likely they washed the engine bay down which possibly got water into the coil or around the leads may have put more load on the coil and then it pact it in hard to say though why it failed
2010 Mondeo Zetec TDI
fordmondeoman is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2011, 10:15 PM   #4
NO2
Old Man
They did wash the car. I haven't been around to check if they washed the engine bay. But that's a possibility
Old 23-01-2011, 03:58 PM   #5
Talldude
Talldude's Avatar
I actually just changed my coil(after market part with after market leads) on my 03 LR focus and I have noticed that it starts better and it also idles better then before. Did have a few times when it took a couple of turns of the ignition to start the car.
So I am guessing these coils don't last long I'm afraid.
LR Zetec 3-Door black
With ST170 Suspension all round, ST170 Snorkel, K&N air filter, 2.0 Auto Air deflector, MSD Ignition coils and high amp leads. (In red adds at least 5bhp!) Also Under pulley kit. Refreshed ST170 wheels now!
Talldude is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2011, 05:16 PM   #6
WILDB
WILDB's Avatar
A Service is only a minor service.
Unfortunately these things can just fail. I'd say it's an unfortunate conincidence that it happened directly after a service.
WILDB is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2012, 10:43 AM   #7
player110
Question Re: Sudden coil failure after service
Could this cause a pinging noise.(Failed coil)
player110 is offline   Reply With Quote Multi-Quote with this Post
