Old 23-01-2012, 02:37 PM   #1
Kizza675
Default 2010 Zetec wheel alignment?
Hi all,
Had a search through the forums,
My focus, which has been serviced religously has developed an irritating misalignment on the LHS rear wheel.
no matter how many alignments i get done (3 so far including a tyre change for that wheel) it persistantly develops that annoying whump whump sound associated with an out of alignment wheel.
I'm at the point of asking Ford to check the axle for problems.
has anyone any ideas, or had similar issues?
Any advice is welcome.
Thanks
Kizz
Kizza675 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2012, 05:46 PM   #2
Neale
Neale's Avatar
Default Re: 2010 Zetec wheel alignment?
Hi Kizza,
My guess is that its either a buckled rim or a bearing in the wheel hub.
If you haven't already, try a wheel rotation. If the problem stays at the back LH side then its not the wheel.
I would then try maybe getting the bearings replaced.
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2012, 06:05 PM   #3
Kizza675
Thanks Neale.
I'll give it a shot
Old 23-01-2012, 06:36 PM   #4
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
I'd be replacing the wheel bearings. It's not an alignment issue.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 23-01-2012, 09:57 PM   #5
crowv85l
crowv85l's Avatar
yeah i would agree wheel bearings, just had to get them done in a ve commodore warranty job. made that whump whump sound your complaining of
crowv85l is offline   Reply With Quote Multi-Quote with this Post
