Just checking, is the clutch pedal part of the pedal box or is it seperate for the V6 Gt Capri's.
I am hopeing it sits further to the left by itself because otherwise i just cut up a Auto v6 GT capri. |
It attaches to the pedal box, but it's the same for 1600 Capris also. If untampered with / modified, a genuine auto capri has a rectangular cutout on the trans tunnel for the shifter, where a V6 manual has an odd 5 sided shape that suits the base of the V6 manual shifter. A 1600 manual will just have a round hole with a raised edge.
There are other ways to tell a V6, any photos of the remaining panels from the engine bay and inner guards will help to identify. Cheers Jamie |
From the firewall foward is sitting 6 feet to the side of the rest of the car & the entire floor is at the dump.
The pedal box only has the acceleraor & brake pedals with no where for a clutch pedal to hang, the brake pedal is on teh extreme left of the pedal box. |
If it was built in 1970, the number stamped on top of the drivers shock tower will start with a JF for an Auto GTV6.
Does it still have its compliance plate? If so, the trans code for a V6 auto is Y. |
