Closed Thread
Old 11-02-2012, 11:34 PM   #61
AU1XLS
AU1XLS's Avatar
Default Re: refill gas bottles
Originally Posted by au3xr6
if you are talking about refilling it from the bowser used for cars it is illegal and dangerous. the BBQ cylinders do not have the safety cut off that cars do . BBQ cylinders are only designed to be filled by decanting not by pump. If I saw anyone trying this at a servo I would be out of there then I would be calling workcover I don't want to die in an explosion caused by someone trying to save money
Close, and last but not least
http://mines.industry.qld.gov.au/***...y_alert018.pdf
Its the same for all states
AU1XLS is offline
Old 11-02-2012, 11:52 PM   #62
GasoLane
Former BTIKD
GasoLane's Avatar
Regardless as to whether you can rock up to your local servo and fill your BBQ bottles, or use your Acme adapter to top up your cigarette lighter, it's against the Law.....
Originally Posted by Caravan and Motorhome Books
Filling a gas bottle with Autogas is illegal. ‘It is illegal to fill an LPG cylinder, intended for domestic and portable appliances, from an automotive LPG dispenser’ states Energy Safety's Office of the Technical Regulator
http://www.caravanandmotorhomebooks....ogas_risk.html
Originally Posted by woolworths petrol
The filling of LPG bottles on the back of registered forklifts is not permitted at our sites. As per AS 1596, bottles must be fitted with an automatic fill limiting valve and permanently mounted
http://www.woolworthspetrol.com.au/Safety
Originally Posted by BOC
7. The filling of any cylinder (other than automotive) from a service station bowser is an offence.
https://boc.com.au/boc_sp/au/safety/...fety.asp?nav=2
Originally Posted by Fire and Rescue NSW
Cylinders used for household purposes must not be filled with automotive LPG (Autogas).
http://www.fire.nsw.gov.au/page.php?id=716
GasoLane is offline
Old 11-02-2012, 11:52 PM   #63
MarkAW
Originally Posted by AU1XLS
In part yes but you also have to change jet sizes due the differences in specific gravity between the two gases
When you fill a bottle at a servo from a dispenser designed to fill cars what mix exactly are you getting? Not a guessing game I would like to play
Its not the difference in specific gravity, its the different oxygen requirement of the gases. Propane requires 5 molecules of oxygen (O2) to 1 propane molecule (C3 H8) where as butane needs 2 butane molecules (C4 H10) to 13 oxygen molecules. So depending on the butane mix you reduce the jet size accordingly.
__________________________
They call it a rort when they're not in on it
Mark
MarkAW is offline
Old 12-02-2012, 12:06 AM   #64
AU1XLS
AU1XLS's Avatar
Originally Posted by MarkAW
Its not the difference in specific gravity, its the different oxygen requirement of the gases. Propane requires 5 molecules of oxygen (O2) to 1 propane molecule (C3 H8) where as butane needs 1 butane molecules (C4 H10) to 13 oxygen molecules. So depending on the butane mix you reduce the jet size accordingly.
Spot on but trying to keep it simple so people get the idea
And dont forget the limits of flammability between the two gases
We could go on and on and but I think by now the masses might have the general idea that is dangerous to do what the OP was proposing to do
AU1XLS is offline
Old 12-02-2012, 12:15 AM   #65
Pinkbits
Pinkbits's Avatar
I think we are finished here.
Rules & regulations regarding filling of receptacles other than what is recommended are in place for a reason.
Pinkbits is offline
Closed Thread
