Old 19-02-2012, 10:55 PM   #1
XARATE
XARATE's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Quality contribution which has gone somewhat un-noticed so far.
Default Crankcase vacuum pump on wet sump system
Hey guys im just after some advice on the use of crankcase vacumm pumps on a wet sump set up. If anyone has experince or knowledge of this set up can you please pm me. I would like to keep conversation private untill i expand on my knowledge and my idea so i dont look like an idiot when i explain what im planning.
270rwkw BA XR8
http://www.fordforums.com.au/showthread.php?t=11339147
XARATE is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2012, 08:07 AM   #2
prasac
prasac's Avatar
Default Re: Crankcase vacuum pump on wet sump system
NA or Forced Induction? street or race? make sure you have leave plenty of clearance for the oil pickup, seen alot of sumps get sucked in a little, which starved the motor and engine died. i'm running a Moroso 4-vane pump on my combo, very simple setup, any excess oil gets sent directly to a tank behind the tyres.
relief valve on the other side
prasac is offline   Reply With Quote Multi-Quote with this Post
