Old 18-02-2012, 06:29 PM   #1
dylancox
Default Petrol to Diesel Conversion?
http://www.greendieselcorp.com/index.html
This group claims to have converted an alloytec motor to run on diesel? Is this possible? Click 'next' 3 times on the webpage to see the details.
dylancox is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 06:36 PM   #2
babyf6
Young Ford Enthusiast
babyf6's Avatar
Default Re: Petrol to Diesel Conversion?
would like to see this work in person,
could be a good idea, though you would want to be licenced as it could go bad if people try to convert at home
Ol Reliable: 2004 Ba Sr MkI
The Fun Machine: 2007 Bf XR6 Ute MkII
babyf6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 06:43 PM   #3
dylancox
Falcon i6 with cast-iron block would run pretty nicely? XR6T diesel?
Old 18-02-2012, 06:46 PM   #4
babyf6
babyf6's Avatar
would get more people buying falcons, as diesel is cheaper to run, would give a good incentive to buy them.
Fast car with efficient engine, always a winner.
Old 18-02-2012, 07:05 PM   #5
Kryton
Kryton's Avatar
Heard of them several years ago and even enquired about converting the Falcon to Diesel but they werent at that stage yet.
Old 18-02-2012, 07:30 PM   #6
OzJavelin
OzJavelin's Avatar
Wasn't the Oldsmobile 350V8 petrol engine converted to diesel at the factory .. Ie. It's the same basic engine converted? (could be wrong) ..
BTW: I think the Olds diesel wasn't much to write home about .. :(
OzJavelin is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 07:34 PM   #7
TMC
SY TS AWD LPG TEZZA
TMC's Avatar
Don't you need more rings on the piston with diesel. I don't think a petrol motor would handle the forces involved. Diesels are beefier from the get go.
1st car 75 XB Fairmont wagon 302C converted to 351C.
2nd car 82 ZK Fairlane 351C 4spd AOD LPG/Avgas
3rd car 97 EL Falcon police car 4L auto dual fuel
4th car 90 XF ute (work car)
5th car 06 SY TS AWD Territory Orbital LPi
6th car 95 XG ute
7th car 2014 SZ Territory TX Petrol
Fords all my life.
TMC is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 08:07 PM   #8
FrogInASock
Getahaircutandgetarealjob
The Olds 350 V8 diesel was based upon the equivalent petrol, but they were different enough to be regarded as seperate engines. And they apparently weren't too reliable in the long term, as you said.
Te pilos recidene volo et opus solidus capere :
FrogInASock is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 09:53 PM   #9
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
If an ultra high pressure injector was the answer to NOX Emission problems, OEMs would be all over it.
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 10:19 PM   #10
pottery beige
that site hasnt been updated in three years..
another hairy armpit greeny save the planet bs mob.....
pottery beige is online now   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 11:57 PM   #11
belvo
belvo's Avatar
who in there right mind would actually convert there car to diesel when there is already cheaper safer and easier option lpg.
belvo is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2012, 06:18 AM   #12
chevypower
chevypower's Avatar
The world still hasn't learnt its lesson that petrol engines converted to diesel just don't work?
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2012, 07:31 AM   #13
jpd80
jpd80's Avatar
I'm sorry but the block architecture of a lightweight alloy petrol engine isn't strong enough
to support the heavier rotating mass and bigger bearings of Turbo diesel engine.
And forget about small NA diesels today, they just don't cut it against modern DI petrol engines...
The problem with NOX Emissions comes from efficient combustion of small amounts of fuel,
the trick is to increase density of charge without spiking compression pressure and temperature.
Old 19-02-2012, 09:07 AM   #14
charles_wif_xf
Purveyor of filth
^ This.
An allow block engine is not up to the task of running diesel, period. However, a Falcon I6 with beefier conrods, pistons to suit and an iron head, it could be an oil burner....
charles_wif_xf is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2012, 09:26 AM   #15
chevypower
chevypower's Avatar
Originally Posted by charles_wif_xf
^ This.
But then why bother? The only thing that is usable is the cylinder block. Ford already has some beautiful diesels out there. 3.0 V6, 4.4 V8, and 6.7 V8 all with CGI blocks.
Old 19-02-2012, 09:28 AM   #16
Nic85
^ This.
I'll assume "allow" is meant to be "alloy", and I'll say that, that is not the case anymore. I'm pretty sure the Euro's are using aluminium blocks for their diesel engines now, but I know for sure Mitsubishi used an all aluminium block and head for the 4N13 in the new ASX.
http://en.wikipedia.org/wiki/Mitsubishi_4N1_engine
Nic85 is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2012, 09:30 AM   #17
babyf6
babyf6's Avatar
wheres mythbusters when you need them
Old 19-02-2012, 10:27 AM   #18
charles_wif_xf
Purveyor of filth
Yes, that was meant to be alloy lol. CURSE THE SPELLING DEMONS!!!
Old 19-02-2012, 10:31 AM   #19
ebxr8240
Performance moderator
ebxr8240's Avatar
Modern computerised diesels don't bang and thump like the old
mechanical injected motors..
In the past there has been some failures like the 350G.M to diesel etc
The motor in the old Mk4 Zephyr was designed as a diesel on the drawing board.. Same motor that was in 3ltr Capri's..
The new diesel motors have heaps of refinement behind them and pass all sorts of EPA.. I doubt converting will be legal ???
Daily driver GTE FG..
Old 19-02-2012, 08:49 PM   #20
Bossxr8
Peter Car
Bossxr8's Avatar
Modern diesels do use alloy or CGI blocks, but you can bet they are quite beefy to handle very high compression most diesels use. A normal petrol alloy block wouldn't be up to it.
Old 19-02-2012, 11:52 PM   #21
music189
I read somewhere in the new Terri stuff before it was released that Ford had got the I6 to run on diesel but the program got cut
music189 is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2012, 06:48 AM   #22
jpd80
jpd80's Avatar
Many years ago Geoff Polites desire was to see an I-6 diesel in the Territory,
cost and the availability of the 2.7 V6 diesel were the reason it wasn't pursued.
Old 20-02-2012, 07:18 AM   #23
wrongwaynorris
wrongwaynorris's Avatar
When Japanese high speed diesels first started to become popular in the late 70's & early 80's the same morons who rubished Range Rovers also rubished Perkins , Gardener Denver , Lister and Petter engines . If a diesel is designed and built correctly it will last forever .
Chevy badges , the Polariser of the new millenia .
wrongwaynorris is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2012, 07:56 AM   #24
Nic85
The newer diesel engines are moving to lower compression ratios to improve NVH and smoothness. The 4N13 in the Mitsubishi ASX for example runs a 14.9:1 compression ratio, the new Mazda Skyactive diesel and petrol engines both run 14.0:1 compression.
Old 20-02-2012, 09:41 PM   #25
Bossxr8
Peter Car
Bossxr8's Avatar
Yeah, I remember hearing that. And the Skyactive petrol compression was up to around 14:1, which is sky high for a petrol, they obviously came up with some sort of trick way to keep detonation under control.
Extremely unusual for a petrol engine to nearly match an alternate diesel's compression.
