Old 29-11-2005, 02:51 PM   #31
NC 5ltr
NC 5ltr's Avatar
692 kbps using a wireless router with the modem about 20 metres away.
EDIT: used the oz test and got 1077kbps using a service providers mirror (iinet)
QUOTE I hope your opinion of the rear end of the VE improves because you are going to be seeing a lot of it.QUOTE
QUOTE What makes you think I'm going to park behind a VE? I don't even attend the Sydney Gay Mardi Gras! QUOTE
NC 5ltr is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 03:08 PM   #32
NC 5ltr
NC 5ltr's Avatar
just ran the oz speed test again......689.6kpbs......so there is definatly some interference somewhere.
Old 29-11-2005, 07:14 PM   #33
outside
off in outer space
outside's Avatar
my speed on adsl
Your connection speed:
kbps: 419.9
KB/s: 52.4875
Mbps: 0.41005859375
outside is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2005, 12:55 AM   #34
nang3
nang3's Avatar
well i just gave the ozspeedtest a go and got
kbps: 3962.1
KB/s: 495.2625
Mbps: 3.86923828125
using the cable test i got;
kbps: 4626
KB/s: 578.25
Mbps: 4.517578125
both are less than half what my plan is and both were using the Iinet mirror which is also my ISP...
nang3 is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2005, 01:17 AM   #35
CSV_LS1
I used to have a nice car
CSV_LS1's Avatar
Originally Posted by Quasi
As already stated, use these as a rough guide only. Server traffic, Line noise, Network congestion, etc....all play a part in your 'CURRENT' line speed.
I think somebody stated they had 282 on a 1500 connection plan. That's disgusting. Are you with a Veridas ISP? There are some issues at the moment in some areas.
Personally, if that was the best my ISP could do, and all my equipment was tested and given the all clear, I would change to another ISP....in fact, I did!
*NOTE*
I had to add this as a seperate reply to the topic, because I couldn't edit my post after 10 mins WTF!!??
I'm with iinet.
CSV_LS1 is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2005, 10:44 AM   #36
nang3
nang3's Avatar
Originally Posted by CSV_LS1
I'm with iinet.
hey buddy you should be getting better than with iinet.. maybe you've got spyware or something choking your net connection??
try downloading Ad-Aware from here;
http://www.download.com/Ad-Aware-SE-...bj=dl&tag=top5
and spybot from here;
http://fileforum.betanews.com/detail...y/1043809773/1
install both and check for updates using its inbuilt updater, then scan your machine.. i wouldnt be surprised if they pick up a few malware things.. Oh and use the Immunise feature of spybot as well
cheers
