04-09-2012, 07:32 AM | #1 | ||
Hey guys I own a EA falcon and on the weekend I pulled out the old CPI engine and put a EB XR6 in it. It turns over but won't fire. I think all the hoses and wires are in the correct place but I'm not sure plus ive got a few hoses left over.
Can someone that has done this conversion or another MPI engine in a CPI car please help Last edited by laurencelr1; 04-09-2012 at 07:34 AM. Reason: Nee title |
04-09-2012, 08:26 AM | #2 | ||
one question I have for you
what dizzy did you use did you use the one of the CPI or the one of the MPI as they are different internally there is a metal plate/disc in them that has from memory one has 3 tabs on it the other has one tab (cfi) it was the problem i had when i attempted my changeover years ago Jason
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
04-09-2012, 08:56 AM | #3 | ||
meh.
Did you change the ECU? I think the wiring is different somewhere too...
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
04-09-2012, 09:03 AM | #4 | ||
You need to tell us whether you're missing spark or fuel.
You need to change the ECU, fuel pump and distributor along with the more obvious stuff. There may also be a single pink wire floating around near the ISC which you need to tap on to the tacho signal wire off the main loom if you haven't already. |
04-09-2012, 10:31 AM | #5 | ||
Im using the distributor that came with the XR and I changed the ECU which didn't do anything havnt seen a pink wire yet
04-09-2012, 10:36 AM | #6 | ||
There is fuel but no spark
04-09-2012, 10:39 AM | #7 | ||
MY2010 SV6 SIDI -Black-
dead dizzy?
04-09-2012, 11:22 AM | #8 | ||
I dunno yet it looks alright
04-09-2012, 12:47 PM | #9 | ||
Did you use the inlet manifold loom from whatever XR motor you put in the car?
Was the ECU a Smartlock one? If it's a Smartlock ECU then there's your first problem. What year and series is your EA? And what year/series is the EB XR loom? |
04-09-2012, 01:34 PM | #10 | ||
Yer I used the inlet manifold that came withe the XR. The ECU was out of another 5 speed EA. The EA is an 89 and the EB XR6 is a 93
04-09-2012, 05:58 PM | #11 | ||
Like FPV said about the smart lock
there should be 2 green wires thats is the smart lock I had trouble firing a Windsor 5 litre but when I joined the two greens together it fired just a thought John |
04-09-2012, 06:01 PM | #12 | ||
It's a normal ECU. Could it be a wiring problem?
04-09-2012, 06:12 PM | #13 | ||
Smart lock would not allow the engine to turn over though.
Do you have spark at the coil?
1976 XB Falcon 500 Wagon - BUILD THREAD Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop |
04-09-2012, 06:19 PM | #14 | ||
I dunno I havnt checked. I pulled one of the spark plugs out, put the plug lead on it, sat on top of the engine to see it spark and turned the engine over and I couldn't see any spark
04-09-2012, 07:34 PM | #15 | ||
Change the loom in the manifold to an EA one just to be safe, and try get one around the same year and series as your EA. I think there could be differences in the EB one that may be causing your dramas. If you don't have wiring knowledge this would be the easiest way to go.
I am placing bets on the coil -ve wiring being out of whack somewhere. This is usually the issue. |
04-09-2012, 07:36 PM | #16 | ||
Ok then. What's the option if I have wiring knowledge?
04-09-2012, 08:07 PM | #17 | ||
Well you can test if you have spark at the coil by arcing the lead between the coil and dizzy cap to the block while turning over the engine.
*Note - doing that can be dangerous! Electricity hurts. Don't do if you're not comfortable.
04-09-2012, 08:57 PM | #18 | ||
I'm comfortable doing anything being an apprentice mechanic. Just wish I was more experienced so I could have got it right
