Old 11-01-2013, 06:28 PM   #1
tim_pato
tim_pato's Avatar
Default vct solenoid fault code in dedicated gas ute?
After putting a hp intech in my ded gas ute i took it to a gas mechanic to run the scan tool and otherwise try and tweak the system. when i went back he said oxy sensor and stepper motor where running fine but there was a fault code for the vct solenoid and he couldnt jelp me with it. went to ford who then could not find my ecu code on there system. he also said the gas ecu might run the vct? that got me a little excited, i spoke to a bloke (mechanic) in the service area who said they would have to run the ford scan to.know more but he said the ecu probably wouldn't run the vct motor. but if the ecu wouldnt run the vct why would it register a fault? also the bloke at the desk said there was only 5 ecu's on fords system gas 6,8 auto and manual.
au2 dedicated lpg tonner, just want a wee bit more stab.
wanted TS/TL50 front seats any condition pm me
tim_pato is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2013, 11:22 AM   #2
tim_pato
tim_pato's Avatar
Default Re: vct solenoid fault code in dedicated gas ute?
there is also a connecter near the main engine connection that one of the vct solenoid wires go to? well it would if the vct motor was in there.
Old 13-01-2013, 06:35 PM   #3
block58
block58's Avatar
VCT is a hardware feature, not a software feature, so it cannot be enabled by an ECU. Strange how that is the fault code coming up though.
FG MkII G6 Ecoboost in Lightning Strike
block58 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2013, 07:10 PM   #4
tim_pato
tim_pato's Avatar
im thinking maybe the bloke at repco read the code wrong?
