Old 29-06-2013, 10:52 PM   #1
buddy92
Default E10 or premium?
I know this question has been done a million times, but I want to see if there's any solid evidence.
I always use premium ( they are all around 1.65 out here) and was wondering if there's any solid evidence saying that it is bad for my FG XR6 N/A? Giving the normal fuel is as low as 1.40 out here now it's a huge difference in price, but would it effect the car?
buddy92 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2013, 11:27 PM   #2
Itsme
Experienced Member
Itsme's Avatar
Default Re: E10 or premium?
Why would it be bad for your car when it is designed to take E10.
Use it & work it out for your self.
Old 29-06-2013, 11:35 PM   #3
Billydean
White Rock
Billydean's Avatar
My mate uses normal and was told by his mechanic to disconnect the battery before changing from premium to reset the computer.
Billydean is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2013, 11:36 PM   #4
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
waste of time disconnecting the battery
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2013, 11:55 PM   #5
buddy92
Sometimes asking can prevent problems from happening.
I would imagine I get better mileage from premium though.
Old 30-06-2013, 12:10 AM   #6
Itsme
Experienced Member
Itsme's Avatar
I used E10 with no problems to my FG XR6 Ute & you know it has been discussed on this forum many times....
It will not cause problems since the engine is designed for it otherwise Ford would not recommend the fuel.
Old 30-06-2013, 12:19 AM   #7
ratter
ratter's Avatar
it should not cause problems but performance may suffer if it is lower octane E10 and fuel economy will be worse
Old 30-06-2013, 09:20 AM   #8
cheap
Wirlankarra yanama
cheap's Avatar
Only you can answer the question, it is your car and your driving technique.
From a pure financial perspective
E10 $1.40/ltr
Straight 98RON $1.65 (or roughtly 18% more expensive)
Therefore for 98RON to be "financially better" your car has to achieve 18% better milage using 98RON than when using E10.
My old clunker happily runs on 91RON, and when using E10 based on my vehicle and driving style, E10 is a complete and total waste of time money and effort...
cheap is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2013, 01:23 PM   #9
BA-XT
2003 BA Falcon XT
BA-XT's Avatar
Wife's vt commy did a fuel pump running that e10 cr4p from United. I tried to tell her..... Mechanic said stick to 91.
I use 95 or 98 in my BA. This fill up I only got 14.85/100km cause I did all short trips. That was on 98 Ron. Depends on your driving habits and if you do much freeway work.
2003 BA Ford Falcon XT
IMPCO LPG Vapour Injection.
DETAILING
Meguiar's NXT Car Wash
Collonite #845 Insulator Wax
Bowden's Own Happy Ending & Fully Slick
Chemtech CT-18 Truck Wash (Wheels & Chassis)
Bowden's Own Wheely Clean & Tyre Sheen
Bowden's Own Three Way Paint Decontamination Spray
OILS AND FILTERS
Nulon Full Synthetic 10w-40
Nulon Long Life Coolant
Ryco Oil & Air Filters
My Instagram Account: @ba_falcon2003
BA-XT is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2013, 01:29 PM   #10
Billydean
White Rock
Billydean's Avatar
They don't have E10 up here any more, they stopped it years ago because of the damage it was doing, I wouldn't go anywhere near it.
Old 30-06-2013, 01:38 PM   #11
Billydean
White Rock
Billydean's Avatar
Well he's a mechanic, and works for the local Ford dealer, so I think I'd listen to him first.
He said to disconnect and reconnect for the ECU to remap itself to the lower octane.
Old 30-06-2013, 01:51 PM   #12
Itsme
Experienced Member
Itsme's Avatar
I agree with Ratter no need to disconnect the ECU.
Old 30-06-2013, 02:00 PM   #13
XR6T0Y
Half brain dead already
XR6T0Y's Avatar
I'd agree with Ratter 'cause he's a hell of a lot more knowledgeable than your mechanic
"My Shockwave Baby"
Running tuned at 191.3rwkw with 475nm Torque
Pacemaker PH4490 + Hiflo Pacemaker cat/catpipe + Xforce 2.5' catback into dual pipes after Diff.
FG Manifold + Herrod airbox + 20% underdrive +Hi flow thermostat + 26mm radiator and Weapon X coils!
Now rolling on staggered Matte black Lesnso D1R's
NOW MANUAL!
Shockwave Blue!
More to come
Now the proud owner of a '97 NL Fairlane
XR6T0Y is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2013, 02:33 PM   #14
malazn mafia
Boss 335
malazn mafia's Avatar
Used to run e10 in an EL. Stopped when one day fuel started purging out the rear of the car while driving along. Inspected fuel pump and fuel line was literally eroded as if by acid. Since then have never touched e10, the 'garbage fuel'. E10 is only worth it if priced at 1.10 or less.
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2013, 03:39 PM   #15
Struggo
Struggo's Avatar
100,000km plus on my FG, faultless and efficient with E10.
E10 in my 2004 TL Magna is another matter as she runs like a dog, so I stick to 95ron.
Struggo is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2013, 04:28 PM   #16
ratter
ratter's Avatar
it's good you have someone you trust to give you advice, next time you talk to him get him to explain how it works and what sort of time period is required for learning, please let us know what he says
Old 30-06-2013, 08:33 PM   #17
tezxr8man
I had similar problems with my EB when I bought it.It is corrosive over time
I find it hard to believe it can be good for your car when it absorbs moisture. After sitting for a bit the fuel pump was buggered and the injectors, I replaced the tank, pump, fuel lines, injectors and rail to get rid of the corrosion in the system, now it is working fine, If at a pinch I would use it if it was going to be in there for a short period of time but not continuously
tezxr8man is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2013, 08:41 PM   #18
Lotte
YE-US! Wait. I don't know
Lotte's Avatar
I think the thing people are forgetting is newer cars are designed better for E10.
Comparing an FG to an EL in relation to running E10 is like comparing an EL to an XA on unleaded.
"Well. Apparently you're looking for a lion-snake named Harriet."
Daily: '06 BF XL Ute,Shockwave Blue, Column Shift, eGas BEAST.
Gone: 77 HZ panel van, 253, column.
The Weekender: '06 BF Pursuit, Toxic, lumpy af
Lotte is offline   Reply With Quote Multi-Quote with this Post
