08-08-2013, 10:31 AM | #1 | ||
nufnsus
Morning all,
Just a quick question on this, my misses has a 09 Fiesta Zetec and i was thinking about putting HIDs in it. as it has projector lens and also are adjustable. My question is, will the HID kit etc start to ruin the lens and plastic cover/housing? As someone said to me they get too hot for the Zetecs?? Some info would be really good!!! Cheers. |
08-08-2013, 10:46 AM | #2 | ||
EL GHIA LIFE
You'll be fine with HID bulbs in the fiesta, just buy a decent kit and a good K rating. Keep it around 5k and you'll be fine. As for the heat, HID bulbs will run cooler than most Halogen bulbs.
SILHOUETTE 07 BF MK2 Turbo, FR19 SIMMONS, ZF AUTO, NIZPRO, GTX, CHINA BEIGE INTERIOR, /////ALPINE AUDIO, PEDDERS XA COILOVER'S. HERITAGE GREEN EL GHIA, ROH MODENA WHEELS, /////ALPINE AUDIO, PEDDERS XA COILOVER'S |
08-08-2013, 11:40 AM | #3 | ||
nufnsus
Thanks War40T - that's what i thought about the temp of them too.
Cheers! |
08-08-2013, 11:54 AM | #4 | ||
EL GHIA LIFE
No worries mate
11-08-2013, 05:04 PM | #5 | ||
nufnsus
Got the kit, but you cant put the metal clip back over it to secure the hid globe in place?
Any ideas how to install the kit? And also how to secure the HID globes in place? Help would be great!! Even better of someone has some pics Cheers!! |
11-08-2013, 07:07 PM | #6 | ||
EL GHIA LIFE
If they are the correct globes for the car they should slide in and the clips should work..
Seating any globe can cause grief, just make sure it's the correct globe and its in the right way. As for fitting, did it come with a wiring diagram? They are pretty easy to put in just by looking at them.
11-08-2013, 07:13 PM | #7 | ||
BF XR8 Ute
Did you get the right hid kit,what type of bulb was in it in the first place.i have know installed 2 hid kits,on 2 different fords and best place for ballasts is on the metal bar strengthener behind bumper bar,keeps them cool while driving.Getting the clips back on behind the globes can be a PIA,but is doable.But not sure how much room you have behind bumper under headlight on a Fiesta,mine have been ba and bf installs.
Cheers Geoff _____________ HIS 2006 BF MKII XR8 Ute,Shockwave Blue. HERS New One Coming Past Rides:- XD Panel Van,XE Panel van,XF Wagon,ED Wagon,BA Fairmont,LX Focus Greetings Earthlings. |
12-08-2013, 09:43 AM | #8 | ||
nufnsus
Yeah the Fiestas runs a H7 globe - so its a H7 HID kit, the globe itself fits in there, but unlike other cars that have a metal clip that goes over the normal light globe to hold it in place, the metal clip for the Fiesta is semi inbuilt into the plug itself (when u plug the normal globe into) and wont fit over the HID fit cables etc.
I hope this makes sence :/ the misses really wants the kit in her car haha Cheers!! |
12-08-2013, 11:11 AM | #9 | ||
EL GHIA LIFE
Can you take a pic of it? You may need to modify the plug and clip by the sound of it.
12-08-2013, 12:00 PM | #10 | ||
nufnsus
Yeah, ill take a pic of it all tonight and post up here
Cheers. |
12-08-2013, 12:45 PM | #11 | ||
EL GHIA LIFE
I found this on a Fiesta Forum
For fitting its just like a normal bulb but does differ as you will need to have the bulb go though the cap into the lights. On the fiesta it's only a rubber cap so just cut a small hole and the grommet on the cables will make it watertight. Plug the positive and negative into the original bulb power source and secure the ballast And Found these http://www.ebay.com.au/itm/2x-H7-Xen...-/221031075339 That may help you out a bit
12-08-2013, 12:59 PM | #13 | ||
EL GHIA LIFE
Glad to help out
16-08-2013, 12:06 AM | #14 | ||
nufnsus
Fitted the HID kit with new clips and its great! Looks great too, misses loves it! Only thing now is i need to find safe spots for the ballest as there kinda just wedged inbetweeb parts... with cable ties... (yes very dodge...) any ideas anyone?
Cheers! |
