22-01-2006, 11:01 PM | #1 | ||
Force Fed Fords
Anyone know any easy ways/tricks to remove etag holder from inside windscreen?
2021 Focus ST-3 Mountune Enhanced |
23-01-2006, 03:29 PM | #2 | ||
Irregular Member
Quickest way(and dumbest) - Smash the windscreen
If its mounted on double sided tape use some fishing line to cut it off then: The best way to remove stuff from glass is to use a new razorbade scraper with soapy water, and only scrape vertically. To eliminate scratches don't scrape back and forth, only in one direction. If there is any glue reisdue left then some turps or simmilar will remove. Be carefull of the screenprinting on the glass! |
23-01-2006, 05:14 PM | #3 | ||
Force Fed Fords
Cheers, will try all but first method.
23-01-2006, 05:18 PM | #4 | ||
Eucalyptus oil is good as well
