Old 14-07-2014, 12:44 PM   #1
cowboy
Cowboy
cowboy's Avatar
Default Diff Specialist Vic?
I have bought new ring and pinion sets for my 1957 Dodge Power Wagon which should bring it's cruising speed from 65km/hr to about 80. I need a diff specialist who can fit them as well as re-shimming the spider gears and installing all new bearings. These diffs are rare so I need someone who really knows their stuff, any suggestions? I'm in Northern Vic so Vic or Southern NSW will be fine.
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1930 Pontiac Landaulet
1932 Pontiac V8 sedan
1935 Pontiac sedan
1937 Pontiac 8 sedan
1948 Pontiac silver streak
1949 Ford F3 pickup
1953 Pontiac Chieftain
1955 Austin Champ
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
cowboy is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2014, 04:49 PM   #2
partsguy
Fan of torque steer
Default Re: Diff Specialist Vic?
Keysborough Diffs.
factory 13/ 18-20 Rhur Street
Dandenong.
03 9706 3454
Speak to Tanya, what she doesn't know about diffs isn't worth knowing.
2015 LZ Focus ST, Frozen white with tech pack. Mountune intercooler, intake, Mountune sports cat, Mountune cat-back and Cobb stage 3 tune. FSwerks short shift and the best performance upgrade yet - Michelin Pilot Sport 4's. Quaife LSD.
partsguy is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2014, 05:33 PM   #3
Trevor 57
Trevor 57's Avatar
There is a fantastic bloke here in Shepp, PM me and I will give you his number
Trevor 57 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2014, 06:35 PM   #4
Silver Ghia
Silver Ghia's Avatar
Ash Differential Service,
Rear 363 Neerim Rd Carnegie
Phone: (03) 9569 4846
They specialise in older cars, I had a diff done by them some years ago which they replaced the crown wheel and pinion to do what you are doing, no problems at all.
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 14-07-2014, 08:14 PM   #5
cano355
cano355's Avatar
Give Andrew a call at preston automatics,great bloke and does great work,his located at
41 Nathan drive,Campbellfield
(03)8339 0661
My ba xr6 build thread
http://www.fordforums.com.au/showthread.php?t=11412101
cano355 is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2014, 08:22 PM   #6
cowboy
Cowboy
cowboy's Avatar
Thanks for the replies, I'm away from home for work at the moment but once I get back will get in contact with all the above and see who wants to tackle it.
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1935 Pontiac sedan
1949 Ford F3 pickup
1955 Austin Champ
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
